Thread: Need help with DPD chlorine test
    Jun 2014
    Katy TX
    11
    I am using the TH-100 test kit and trying to follow the instructions on The Extended Test Kit Direction Post for the DPD test. I have the following questions:
    I seem to have no test cell with a 9ml mark. Am I missing something? Do I just use one of the cells and guess by getting close to the 10ml mark?
    What is the test cell marked "Chlorine Only" used for?
    The only color chart I can find in the kit is on rectangular cell included with the Basic Kit. Is this the proper chart to use?
    Saltwater 8000 15ft x 54" pool, Hayward 1hp, 2 speed pump, Cartridge filter, Hayward SWG, TFT-100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Need help with DPD chlorine test
    I suspect that you have the TF100 test kit, which includes the FAS-DPD chlorine test. This test is unrelated to the DPD chlorine test and does not ever make us of a 9 ml vial.
    If you tell use the reagent numbers your test uses we can double check to make sure I am correct.
    In any case, use the instructions that came with your test kit to start with.
    Jun 2014
    Katy TX
    11
    Thanks guys now I get it. I do have the TH100 kit
    Btw why do I have a cylinder marked chlorine only?
    The chlorine test builds up a white film on the cylinder which can interfere with reading some of the other tests. The film can be cleaned off, but it is simpler to use a separate vial for the chlorine test, which isn't affected very much by the film.
    Jun 2014
    Katy TX
    11
    Thanks
