Thread: TA Issue (I Believe)
    Jul 2013
    Grand Rapids, Michigan
    55
    So I'm a little confused about the pool calculator. It seems to only tell me how to increase TA and not decrease it. Here are all my numbers:
    FC 4.25
    PH 7.5
    TA 110 to 120
    CH 170
    CYA 30
    Salt 3800ppm
    Any help would be appreciated.
    23,200 gallon in ground pool, Vinyl Liner, Salt Water, Variable Speed Pump Intelliflow 3hp/1.32SF/3.96 SFHP, Filter Pentair FNS PLus DE FNSP36, Heater Pentair Mastertemp 250, SWG Jandy APURE35PLG, TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: TA Issue (I Believe)
    Why do you want to decrease it? 120 is fine. You're in no imminent danger of scaling. If you just keep maintaining the pH when it rises, it will go down soon enough.
    As it says in the How to Lower Total Alkalinity Article in Pool School
    You shouldn't lower TA just to reach a target number.
    So what is the issue? Is the water cloudy? Why do you want to decrease TA?
    Could you also put your location in your signature or profile?
    Jul 2013
    55
    I'm pretty new so maybe I'm just a little hypersensitive. The water is beautiful so maybe if it's broke don't fix it. I'm in Michigan.
    30,432
    Yeah, I'm with 320.....leave it alone until you have some pH issues which will likely be never. You can read the article in Pool School so you'll know how if you ever have the need.
