green algae - Chlorine or Borax First?
Jul 23, 2008
8
Bartlett, TN
Hello. I have had green algea in my pool for a little over a week. It started appearing at about the same time that my pump started dying. (Actually, I think it has not been working as well as it should for a while now, but I don't know for sure.) I read that I should have a working pump and filter and a good test kit before the big shock. Here are my numbers:
pH = 7.8
FC = less than 0.6 (very very light yellow on my OTO test)
Alk = 90
Stab = 45ish (though I read that this might not be right due to my algae)
calcium = did not test b/c I have a vinal pool and I read that it didn't matter
I looked everywhere for Muriatic Acid yesterday and can't find it, so I walked around sprinkling some leftover pH decreaser that I had previously bought from Walmart in the pool this morning before work (my old pump is still barely turing the water, so I hope it mixes well enough). My question is, assuming that I can find some appropriate acid, which should I do first, the Borax treatment or the Chlorine shock?? I read that Borax can help with algea and reduce the amount of chlorine you need, but I can't find anywhere if there is a problem with using either one before the other. I am taking a vacation day from work on Friday so that I will have all weekend to deal with this if necessary. I just want to have everything prepared before Friday when I begin my war on Algae! I already purchased 6 boxes of 20 mule Borax and 6 1.5 gallon jugs of 6% bleach, and I plan to buy more of whatever I need tonight. (I realize that I need more bleach, but I didn't have any more room in my car last night! :) ) Any advice would be great!!
Hey,
Chlorine (bleach) is your first line of defense against algae. You'll need to put enough clorox in there to get to around 20ppm (now really read this carefully) and you'll need to KEEP IT UP AROUND 20 ppm until your pool clears.
Don't worry about your pH for now. You can adjust that down (if you need to) after you have cured your algae bloom.
I am concerned about your pump but will leave that to you to make sure you can circulate your water. Go get some more clorox....you're gonna need a bunch to get rid of the algae.
Lilsis,
Glad you got your TF100 on the way! This will put you in control of your water and your confidence will soar!
As Dave said, start shocking your pool. You can help 'circulate' your water (mix in the bleach) by using your pool brush or spraying sharp streams w/the water hose.
Good luck and keep us updated.
Welcome to TFP!
Follow Dave's advice as far as getting your FC up to 20 and keeping it there . I would also make the pump repair/replacement a priority because you will make little progress without the ability to turn your water over effectively. Don't forget to brush the walls well too.
Good that you are taking Friday off. You will need a few days to stay on top of things.
