Thread: Top of Steel wall pool exposed
    Jun 2014
    Hauppauge, NY
    19
    I just replace the liner to my inground pool. In order to replace the old curved coping with the new extruded coping (for future pavers) I had to remove the first row of existing brick from around the pools edge. Now that the new coping is installed I have the issue of having the top surface of the steel walls exposed because the brick is no longer there. Most people would say to just put the brick back which was removed; the issue is if I put the brick back around the edge of the pool it is no longer secured in place by the old style coping. This would allow the brick to fall into the pool if anyone was to bang into it with their toe. Is it safe to leave the top of the steel wall exposed (worried about rusting and what not). The original game plan was to get pavers installed around the pool, this was until we got 3 estimates all in the 16k range. Next thought was to maybe just get bullnose coping installed around the pool (guessing approx 4k) until we can afford the rest of the pavers.
    Any thoughts or ideas would be greatly appreciated
    20 x 40 Inground Liner Walled Pool 33,000 Gallons, Hayward DE3620 Filter w/ multiport valve, Hayward SuperPump VS Pump. Stenner Fixed Rate Chlorinating Pump
    Jun 2013
    Phoenix, AZ
    130
    Re: Top of Steel wall pool exposed
    Please post some pictures.
    32K gallon 24'x41' IG, 8'x10' spa, mini pebble,
    Pentair equipment [Intellitouch I9, IC-60 SWG, 520 sq Clean + Clear Plus cartridge filter, 3 VS pumps(1 FX, 2 intelliflo)], Dolphin M5 cleaner.
    2 rain shears, 2 water shears, 2 blubbers, 4 laminars, water slide, rock waterfall.
    Jun 2014
    Hauppauge, NY
    19
    No problem, will once I get home
    Jun 2014
    Hauppauge, NY
    19
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    I would cover the top of the steel wall. It looks to me like someone could accidentally slice a toe or finger or something else on the edge of the steel if it is not covered. You aren't alking about putting loose brick there on the edge are you? That obviously wouyld not be good, but if the bricks are mortared in, that should keep them secure. Or the bullnose coping could be a good idea. At any rate, I would not leave the top of the steel uncovered.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    Pigeonlove's Avatar
    Jun 2013
    Boise, Idaho
    102
    Why don't you just remove that next row of pavers and replace the whole works with something larger?
    12 x 28 Doughboy Dinosaur (j/k: Breckenridge) partial bury, continuous depth 9,000gal. Doughboy Power Pak I digital 1hp pump, Hayward Pro-Series 300lb sand filter. Foam panel base, Gladon wall foam, Gladon cove.
