Greetings,
My pool has been a rollercoaster, or rather taking care of it has been.
We seem to get algae so incredibly easy. Maybe because one long wall of the pool is hit by the sun all day. I dont know, but the algae is a constant battle.
Now another problem, it appears that there are bubbles, or foam in the pool. I think probably from too much chlorine. Any advice for what caused this and how to fix?
Thanks
jillcreyes said:
i checked chlorine and it was about 1.5
ph is 8.3
using bleach from pool store, 12.5%
Sounds like you are using a 2 way tester. That is not enough. We need numbers for free chlorine, combined chlorine, pH, total alkalinity, calcium hardness and CYA (Cyanuric acid or stabilzier).
BTW, your pH is WAY too high.
