Thread: Polaris 380 - expected service life
    Feb 2014
    Phoenix, AZ
    51
    Question for those who have owned a pool for more than 6 months
    What is a reasonable expectation for service life on a cleaner ( like a Polaris 380 ) ? I am going on the assumption that it will be in the pool 99% of the time ( removed only for parties and not for daily swim sessions ) and that my CYA of 60 will mean my FC is around an average of 8.
    Thanks Stu
    20k IG PebbleTec w/ STA-RITE PE5E-182L 1HP and Zodiac Polaris PB4 for Polaris 380 vacuum / Hayward ProGrid DE4820 Filter / TF-100 but I havent broken down and gotten a speed stir yet
    Re: Polaris 380 - expected service life
    A Polaris should last many many years. However, it will require regular maintenance. Typically some small part or another breaks every year or so and needs to be replaced.
    Apr 2009
    Northern Virgina
    55
    I inherited a Polaris 180 that was probably ten years old when I bought my house. It kept going for another ten years and I finally bought a Polaris 280 to replace it. The 180 still works but it was getting to the point where it needed a complete overhaul so I decided it was time to get a new one.
    22k gallon IG Anthony free-form pool and spa with PebbleSheen finish, Pentair WFDS-8 WhisperFlo Full Rated Dual-Speed 2HP pool pump, Sta-Rite S8D110 System 3 Grid D.E. 53 sq. ft. pool filter, Raypak R406A 399K BTU cupro-nickel propane heater, Polaris 280 pool cleaner with 3/4 HP PB4-60 booster pump, Goldline Aqua Plus controller and SWG, Inter-Fab G-Force pool slide.
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    They say the cleaner will clean a pool in approx 3 hours, so it should only be running for about 3 - 4 hours a day, depending on the pool debris and the rpm's are between 28 - 32. Remember it is plastic with gears and cogs so the more you run it and the harder you run it the quicker it will need repairs.
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
    My Polaris 380 is pretty old now (decade?). It's been repaired many times. Myself, I've replaced the filter bag, tail and feed hose. I even rotated the tires. I'll probably do a rebuild kit in another year or two. It cleans my pool in about an hour, by that point there might be a leaf or two if it started out with lots of them, but it's not worth running it more. I'm less worried about wear and tear, but noise and electricity.
    20,000 gal in-ground plaster pool with sand filter. Replastered recently. Mostly adding bleach and acid. CYA was high when I took over.
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    My 380 is about 15-years-old and still going strong. Had to replace some parts and probably bought 2 tune-up kits. It's wicked easy to work on. Rebuild kits are much more expensive than tune-up kits, though, and if I ever thought I needed a rebuild kit, I might just buy a new one.
    BTW, I hear that the 280 is still the best model. Somebody said it's strong enough to suck up the neighbor's cat. With the 380, you'll have to be happy with getting dirt & leaves.
    Good luck!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
