Thread: Will be gone for a week...Levels?
    melbajr's Avatar
    Aug 2013
    Florence, SC
    54
    Question Will be gone for a week...Levels?
    FC=2ppm
    CC=0
    pH=7.5
    TA=70
    CH=75
    CYA=55
    Salt=3870, put in 40 lbs. yesterday.
    Water temp=90F
    Pool Math says add 41 oz/volume stabilizer to raise CYA to 80ppm & 38 oz/vol. baking soda to raise TA to 90.
    My SWG runs @ 60% for 6 hrs/day.
    Also, Hurricane Arthur will rain on us and send 20 mph winds tomorrow which will blow a lot of leaves and such into the pool.
    Do you think I should make adjustments to compensate for my absence?
    Grecian 11,800 gal. IG vinyl, Pentair TA-60 sand filter, 1.5 hp Superflo, built in 2007, replaced vinyl & converted to Intellichlor IC-40 SWG in 2012 after we purchased home. TF-100 Testkit, SWG manufacturer recommends salt levels 2600-4500, ideal being 3400-3500. Polaris 180 vac.
    38,528
    Re: Will be gone for a week...Levels?
    The TA is fine, you do not want it higher with a SWG.
    That FC is bordering on low. I would raise the CYA, but leave the output the same and the FC should come up. Although you should verify that before you leave.
    melbajr's Avatar
    Aug 2013
    Florence, SC
    54
    Hope you had a happy 4th!
    Thanx for the advice
