Results 1 to 15 of 15
Thread: First fill up!
    Jul 2014
    New Orleans, LA
    41
    First fill up!
    Hey all. Been lurking around for a month reading and gathering as much info as possible for my first pool. I purchased an Intex 18' x 48" easy set pool. Rented a sod cutter and removed all the grass, then leveled with sand, and compacted. I was only 1.25" off so it was not to bad, one weekend and a case of beer! I'm using the stock filter with a SWG. I purchased the TF 100 kit and my question is should I test the water before adding the salt and running the generator or after. Any help or suggestions would be greatly appreciated. Thanks
    9000 gallon in ground
    Century main pump with filter basket
    Jandy Cs-250 Cartridge Filter
    Jandy Salt Water Generator
    Polaris Pump
    jmcdtucson's Avatar
    Jun 2014
    317
    Re: First fill up!
    Test the water before adding salt. I made the mistake of not testing and assuming my salt was zero. Ended up adding too much salt and my only option is to drain 1/4 of the water and re-fill. Test before.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Jul 2014
    New Orleans, LA
    41
    Re: First fill up!
    Cool, it is about 3/4 of the way full, can I test now or wait till its full?
    Polaris Pump
    Jul 2014
    New Orleans, LA
    41
    Re: First fill up!
    Well here are the results :
    FC - .25
    CC - .1
    TA - 100
    PH - 7.2
    Any recommendations before I add the salt?
    Polaris Pump
    38,274
    Re: First fill up!
    Those FC and CC numbers make no sense. What are you multiplying by?
    Jul 2014
    New Orleans, LA
    41
    Re: First fill up!
    Sorry,
    FC - 2.5
    CC - 1
    Accidentally multiplied times .05 instead of .5
    Polaris Pump
    38,274
    Re: First fill up!
    You can add salt whenever you want and let circulate a day before turning SWG.
    You also need to get the CYA up to around 70ppm and should maintain the FC level with bleach until the SWG is running.
    Jul 2014
    New Orleans, LA
    41
    Re: First fill up!
    So just add 60oz of liquid stabilizer? I was just at Walmart and they had Pool Basics Liquid stabilizer and conditioner, will this work? Or should I just get the powder form? Of course I am trying to use the pool tomorrow.
    Polaris Pump
    Jul 2014
    New Orleans, LA
    41
    Re: First fill up!
    any suggestions?
    Polaris Pump
    jmcdtucson's Avatar
    Jun 2014
    317
    Re: First fill up!
    You need to test the salt content before adding salt. Otherwise you won't know how much to add.
    For stabilizer make sure it's at least 99% cyanuric acid. Use pool math and punch in your current, goal, and your pool size and it will tell you how much toadd.
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: First fill up!
    Up to you based on how much you want to spend. Liquid is in the pool instantly, but costs more. Dry takes longer to dissolve, but is cheaper.
    Jul 2014
    New Orleans, LA
    41
    Re: First fill up!
    If I use the dry, how long till it dissovles or until you can swim?
    Polaris Pump
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: First fill up!
    Put it in a sock in the skimmer and keep the pump running. Squeeze the sock often, and it will dissolve within a couple days.
    Since it's a fresh fill you can swim immediately.
    Target FC at 2-3ppm for 24 hours after putting the CYA sock in. After 24 hours, assume the CYA is in the water (but don't bother testing for it for a week or so), and raise your FC to the appropriate level.
    jmcdtucson's Avatar
    Jun 2014
    317
    Re: First fill up!
    What he said, it's what I did just a few days ago and my chlorine is now stable.
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    Jul 2014
    New Orleans, LA
    41
    Re: First fill up!
    Great!!!! Thanks for all the help! My Fiance and her son are coming over tomorrow for the 4th so I know they will be excited! I busted my butt this week to get it ready and it looks like I made it by with little to spare!
    Polaris Pump
