Results 1 to 7 of 7
Thread: Pool alarms...any opinions/advice?
    tookiesmom07's Avatar
    May 2013
    Tennessee
    56
    The state of Tennessee requires you to have a pool alarm. Though I know plenty that don't. Not the point...anyways, I was wondering if anyone here has any experience with any that they could recommend for a new above ground pool build. From what I have read, you can't pass the electrical inspection without it. So, I would prefer to have a good one that doesn't go off at the slightest breeze blowing or rain shower.
    Intex Ultra-Frame 26x52 AGP (14,650 gal.)
    Intex Pump & Filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pool alarms...any opinions/advice?
    I have yet to hear of one that is not prone to false alarms
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Locally, we are supposed to have an alarm on every entrance to our pool area. No mention of a water movement based alarm.
    Personally, I think even that is going too far in "protecting us from ourselves".
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    Read lots of review. My pool builder provided one that was absolute garbage. You could tell from build quality that either they have no quality control, or they don't expect anyone to actually use it after inspection is passed...I suspect the latter, based on reviews I later read.
    Having said that, I have seen pool alarms that actually do get good reviews.
    You want one that is easy to disarm, and is not too aggressive about rearming itself...both issues with my unit. Otherwise, you will want to rip it out. Of course, you don't want false alarms either, but my unit was actually good about that for the week we had it installed.
    Read lots of user reviews, and buy from a place with a great return policy.
    (Sorry, I can't remember my make and model.)
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
    wjr75's Avatar
    Jun 2013
    IL
    836
    I have a "pool patrol" that I sometimes use. It floats on the surface and detects waves in the pool if someone falls in. It has a wireless alarm that will also go off in the house. You can take it out of the pool when you don't want to use it. I think I paid around $60 bucks for it on amazon.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    Aside from building codes and passing inspection, I installed alarms to the doors and some windows of the house. They are cheap and can be turned on an off as necessary.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    May 2013
    Tennessee
    56
    Thanks everyone. I too, from what I have read about them don't think they are going to be reliable really. I planned to install some sort of alarm on the fence gate. Figured we could find one of those that would work well. Plus there will be a padlock on the gate too. May seem like overkill, but that's ok.
    Intex Pump & Filter
