Thread: Lower TA
    DSdiver's Avatar
    Sep 2013
    South Eastern Wisconsin
    31
    Lower TA
    Test results as of 1 hour ago
    FC 4.5
    PH 7.8
    TA 160
    CYA 70
    CAL 260
    Salt 3400 ppm
    Our TA is high and has been this season I would like to get it down but after reading how to do it I'm a bit confused. I used the pool calculator to try and adjust it using acid this didn't seem to effective. So as I understand it you lower your PH with acid and then add soda ash,as this will lower your TA but raise you PH?
    Any help I know I'm over reading it thanks in advance
    20x40 IG vinyl lined 34,100 gallon/Hayward filter EcoStar model SP 3400 VSP/Hayward filter(sand) model S310T2 flow rate 98GPM/RayPack gas heater model 266 266,000BTU/Aqua Plus Automation and chlorination with Hayward Turbo Cell T-Cell-15/Hayward universal color logic light/ Delta UV filter/4 return lines 2 skimmers and dual main drains/Auto cover/ Pool is 3 years old. TFT test kit XL speedstir.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Re: Lower TA
    You lower pH with acid and then aerate to bring pH back up. The aeration is exactly what you're doing when you shake a bottle of soda pop.
    There's really nothing wrong with your TA. As it says in the how-to article
    You shouldn't lower TA just to reach a target number.
    38,514
    Re: Lower TA
    No. You add acid to lower pH and TA, then aerate to raise the pH back up so you can add more acid.
    There is NO reason to bother doing this unless you think your pH is rising too quickly.
    The process is in Pool School: How To Lower Total Alkalinity
    Wow ... those 2 posts are nearly identical in structure with different wording
    May 2014
    Mesa, Arizona
    180
    Re: Lower TA
    Copycat!
    IG Pebbletec Blue Tahoe; Paddock Pool PCC 2000 pop-up; 22,275 gal 32' x 16' Diving with Auto-Fill
    Pentair 420 Cartridge filter; 3 hp VS Whisperflo Main Drain, 1 1/2 hp Whisperflo Running Pop-Ups; Jandy AquaPure 1400
    1 1/2 Whisperflo dedicated to Rock Waterfall; TF-100; Taylor K-1766; Pool Built in 1997
    DSdiver's Avatar
    Sep 2013
    31
    Re: Lower TA
    Thanks allot for pointing me in the right direction my wife was right she said it was ok not to lower it.
    Lots another one...lol
    Oct 2013
    Oklahoma
    50
    Re: Lower TA
    This is my first year w pool so I'm no expert but my experience is that it took repeated applications of acid to get TA down. I'm finally down from 150 to 50 now. Added acid to get ph down to 7.0 or 7.2. The ph tends to climb back pretty quick anyway so don't get to anxious about aeration But you will have to keep dropping it down w acid every 3 to 4 days to finally get your TA down. Took about 3-4 weeks for me.
    13000 gallon pool, SWG, DE Filter, 2 sheer descent waterfalls, built Jan 2014
