Results 1 to 7 of 7
Thread: upgrading pump to variable speed
    Jun 2014
    orange county, california
    15
    hi, first post, been reading alot and want to save money by changing the old 2hp pump to an variable speed model.
    a certain deal site has 2 pumps:
    Hayward SP3400VSP
    and
    Pentair 11018 Variable Speed Pump 230-volt.
    will either one be easier to work with my existing controls: Aqualink RS4
    and
    is either pump better than the other, assuming they are the same price.
    15,000 gallon in-ground freeform pebble-tech plaster built in '99
    Pentair Intelliflow 3hp variable speed pump & 2hp whisperflo for waterfalls
    Aqualink RS4 with intellicom adapter
    Pentair 4000 SMBW 30sq.ft. DE Filter
    Pentair Minimax 400 heater
    Re: upgrading pump to variable speed
    Welcome to TFP!
    If your Aqualink was made in the last few years it can control a Pentair IntelliFlo pump directly. Meanwhile, the Hayward EcoStar is slight more energy efficient.
    Jun 2014
    15
    thanks for the input, the pool was installed in year 2000, so its likely just as old.
    i was reading that intelliflow pump can work with aqualink rs4 with a additional intellicom II module for about $150 or maybe i can rig it somehow.
    the deal is going for a few more days and the site is woot.com if anyone else is interested, end up being $700, and hoping to get $200 back from electric company rebate.
    Yes, an IntelliCom II will allow any automation system to control an IntelliFlo. However, you will need one available relay in the automation system for each pump speed you want to be able to use from the automation system.
    Jun 2014
    15
    as expected the aqualink is original 6522 revision HH
    it sounds like i will require the intellicom, ill have to look if i have enough relays to operate? i think ill need 3 relays for the high/low/spa modes, correct?
    is there a cheap hack to do it, like buy a used power center board or cpu, or should i just go the full iaqualink route, when i can afford it?
    Jul 2014
    Franklin Park, NJ
    4
    Quote Originally Posted by tbiz99 View Post
    According to Amazon, the Intellifo to work with Jandy, you need the Iaqualink 900-RS module. the Intelliflo board is useless..
    Inground, Gunite appoximate 36,000 gal. Jandy Aqualink RS4, Hayward's DE collector&chlorinator, DE7220 filter,Jacuzzi Magnum just died, single speed 1.5 hp. Self test kit with Re-agent and test strips.
    Pool - 1995, small waterfall, spa & clearwater ionizer modell 1100, and Aquabot XL cleaner
    Jun 2014
    15
    here is my current setup:
    -filter pump and waterfall are separate 2HP pumps
    -spa and pool light are on separate relays.
    -there are 2 JVA one on input and one on output for spa/pool mode.
    -also a spa side switch that needs to be replaced. (they originally installed the switch under the water level, is this ideal? should i relocate this if and when i replace the switch?)
    Well i found an intellicom II for cheap on ebay, so I'm going to give it a shot in keeping the rs4. Even though I'm really limited on buttons on the controls that are inside the house. I figure i can combine the spa and pool light to free up one aux button. Which would allow 2 speeds. Would this be sufficient? Is there another speed I'm in need of, if so maybe i can rig something...
    filter pump = speed1-faster speed to operate the creepy crawly (this mode also turns on when spa button is selected)
    2nd aux = speed2-lowest setting possible to turn over water.
    also of note are possible extra aux outputs i can use in case i need more outputs:
    Spare Auxiliary. With firmware prior to Rev. I this socket is on when
    the filter pump is on and the system is in pool mode.
    Solar Auxiliary a 4th possible speed i can use, even if it makes the controls a bit more complicated to the end-user
