Thread: Hard piping 16" Intex sand filter on Pro Series pool
    Jun 2014
    marshfield, ma
    9
    Hello all,
    I have a Pro Series pool with the standard skimmer. My goal is to keep the original skimmer and pump and add a new 16" Intex Sand filter to pull water from lower in the pool and improve water movement. I plan on hard piping up and over the side of the pool.
    My questions are:
    1. The sand filter came with plunger valves, is there any value in using these valves or adding ball valves on either the inlet or return? Is this important when backwashing etc.?
    2. Does the fact that the piping comes up and over the side above the water level require any special consideration when setting this up? Will I need to find a way to prime the pump myself?
    Thanks in advance for the help.
    Greg
    5K gal, AG 16'x4' Pro Series, Skimmer with 1000 gph pump and catridge filter + 16" Intex 2650 gph sand filer, Intex Krystal Clear SWG
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: Hard piping 16" Intex sand filter on Pro Series pool
    It is best to have valves between the inlet and pump and between the filter and return. As far as I know the pump should have enough power to self prime, but a better solution is to cut an intake opening or to remove the pump from the skimmer and plumb the new pump below the skimmer.
    Love TFP? Become a
    TFP Supporter!
    Jun 2014
    marshfield, ma
    9
    Ended up just going for it and getting this done yesterday. I put ball valves on the inlet and return just in case even though I could just pull the pipes out of the water to service the pump, I figured it may make it easier to clean the basket without having to disconnect the pipe. The water movement from this unit is staggering compared to the skimmer pump. I think next year before I open the pool I will cut the inlet and returns into the actual liner and I may plumb the skimmer inline with the other inlet.
    I know everyone likes pictures, so I will try to snap a few before the hurricane rolls through here.
    Jul 2009
    Houston, Texas
    9,429
    Be safe! What kind of impact does your area expect from the storm?
    Love TFP? Become a
    TFP Supporter!
    Jun 2014
    marshfield, ma
    9
    I am right on the coast and the eye is supposed to be about 50 miles or so off the coast. The forecast is just calling for heavy rains and a little wind. Nothing we are not used to around here
