Thread: Indoor pool - CYA or no CYA?
    PresidentSkroob's Avatar
    Jun 2014
    Toledo, Ohio
    6
    As far as I can tell, the previous owners of our house did not use CYA in the indoor pool at all. There was none in their pool chemicals, and I got my testing kit today and the test for it came back without any trace.
    Should I be adding CYA, or just run with it as is and figure that's one less chemical to worry about? Resources I've seen online have suggested it's kind of optional... but which is optimal?
    40,000 gallon, 20'x40' in-ground (gunite) indoor pool built in 1976
    Filter: Hayward S-220T (sand)
    Heater: Sta-Rite Max-E-Therm 200
    Pump: Hayward C48L2N134B1 two speed I think
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Indoor pool - CYA or no CYA?
    Scroll down a bit for chemgeek's answers http://www.troublefreepool.com/threa...an-indoor-pool
    38,301
    I am sure the link that Richard provided has a LOT of good info.
    The nut shell: We recommend 20-30ppm of CYA in indoor pools (about as low as you can measure) not for the sun protection, but for the buffering effect so the chlorine is not so harsh on your skin, hair, and suits.
    Jun 2014
    Toledo, Ohio
    6
    Awesome. Thank you!
