Results 1 to 11 of 11
Thread: What kind of pad is this?
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    I'm in the middle of replacing our AGP's liner. I expect to find sand at the bottom because of the squishy and uneven feel over the years. Instead we found this (very stinky too):
    It almost looks like wall foam duct-taped together.
    Should I try to keep? It is kind of wrinkly and uneven. Do I need to go ahead and pull/smooth out the sand?
    Thanks.
    * 18' x 33' - 48" oval AGP - new liner Summer 2014
    * Hayward Pro Series S210T Top Mount Sand Filter
    * Hayward Power-Flo Matrix 1 1/2 hp Pump Model SP5615
    (equipment on posts prior to summer 2014) Hayward PowerFlo 1 hp pump - Jacuzzi "Tidewater" 190L, sand filter
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Re: What kind of pad is this?
    An update:
    • I pulled the duct tape from the seams and removed the foam pad stips from the floor.
    • Wet, uneven sand is underneath with croppings of what appears to be an older liner - not sure if it covers the whole floor.
    • I'm trying to clean the foam and put it back in.
    • Also trying to smooth out the sand without making things worse with footprints. Not doing too good in this department.
    Still not sure what's the story with the foam. Almost looks like a building material item.
    Does the sand need to dry?
    Thanks.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Yup that's what it is.... Heaps of people use the extruded foam underneath the pool... It just gives a nice feel underfoot...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Is this the same thing as wall foam?
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Oh crud, it's Vermiculite, not sand. And it doesn't play well at all.
    Casey's Avatar
    SW PA
    10,453
    How about hauling in about 2-3 tons of clean sand an wet it down, level it out and tamp it down by working from one end of the pool to another. I did this with my last pool. I had the time to spend on it... It turned out really nice.
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    We have a ready mix down the road. Any particular sand to ask for?
    Casey's Avatar
    SW PA
    10,453
    Clean sand. Tell them you're using it for a swimming pool base and they'll hook you up.
    Louisiana
    127
    Looks like something called happy bottom foam pads. had that under mine one time.
    27' Radiant Metric, 17,100 gallons
    Pentair Dynamo 1.5hp 220v
    Circupool RJ45, Sand Filter, Borates
    Dolphin DX6 Robotic cleaner
    TF 100 Kit
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Re: What kind of pad is this - follow-up:
    Okay - a follow-up:
    After researching the sand option, time and logistics were not on my side. I smoothed the floor craters out as best as I could with pool vermiculite but it was not fun to work with. Then put the pads back on and re-taped.
    Went ahead this morning with the help of some family (critical for this) and un-boxed the liner, rolled out,and installed. I am currently at this point, fer inches of water, working out the floor wrinkles.
    Portofino anyone?
    Casey's Avatar
    SW PA
    10,453
    I've got the same liner Onslow! We're on the second year with it and I still love it!
