Thread: Draining to lower CYA.
    Jun 2014
    Iowa
    17
    My CYA is pretty high (150ish). I want to drain off a bunch of water and refill, but I'm not sure if I can drain to below the skimmers without getting air in the lines and having problems. If I close the valve for the skimmers and backwash water out only coming from the main drain will I be OK? Any problem if I drain to a little below the returns, or should I keep the water level just above the returns?
    Thanks in advance for the advice!
    25,000 gallon inground plaster pool with attached spa. Sand filter.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Draining to lower CYA.
    If you can pull from just the main drain, that should work fine. I've emptied my entire pool that way!
    30,432
    Herky,
    +1 what MITS said.
    We are on a roll to get everyone to enter their city and state in their profile. The climate often affects our suggestions. Would you enter yours, please?
    Dave
