Thread: Question about supplementing a sand filter
    Jun 2014
    Houston
    110
    Has anyone ever tried one of these things to supplement a sand filter?
    http://www.lowes.com/pd_565737-42805...BF_4294610223_
    Mind you I would never buy that specific thing however the idea of getting a $30 submersible pump along with some PVC and connecting it to a decent paper cartridge (basically what the makers of that thing did but at total cost about $80 instead of $600) does seem workable.
    30 year old, 17,000 gallon pool (w/spa), IG, Plaster, Pentair Triton II TR-100 600#Sand Filter, Pentair Superflo 340043 1.5 Hp pump
    Re: Question about supplementing a sand filter
    Something along those lines is great for saving energy, but isn't likely to improve you filtering (unless your current filter is actually broken). Even a slightly undersized sand filter is more than enough for any pool. Nearly everyone who thinks they need more filtering actually has a water chemistry problem.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I suppose it could work. Have you tried putting a little DE in your filter? That is supposed to help quite a bit.
    Jun 2014
    Houston
    110
    Currently in the middle of a SLAM and have been dealing with almost no improvement to cloudiness for over 10 days now. Sand filter just doesn't seem to be able to catch the particles even with a cellulose/DE additive.
    The whole thing is documented in this thread:
    http://www.troublefreepool.com/threa...-fix-the-swamp
    Right now whatever is in the water just seems to pass straight through the sand filter and go back into the pool which is why I am considering trying a kitbashed together cartridge system to get whatever this is out of the pool.
    Only losing 1ppm FC overnight so I doubt that there is very much left in the way of live organics still in the pool.
    The filter might be channeled. Try doing a deep cleaning of your filter.
    Jun 2014
    Houston
    110
    Quote Originally Posted by JasonLion View Post
    I just did that a little over three weeks ago before starting the SLAM. No signs of channeling at the time.
    However this morning I added just a bit more cellulose to the filter than the directions on the package called for and (*surprise*) about an hour ago saw a huge spike of 12psi.
    So after backwashing, I went ahead and added the same amount again as I did this morning to see if it continues to improve the performance.
    (Crossing fingers)
