Results 1 to 10 of 10
Thread: New SWG high chlorine
    calespool's Avatar
    Dec 2013
    Savage, Minnesota
    21
    I converted to salt a week ago, its a T15 cell and I was running it at 50%. Chlorine went from 9 on 6/28 to 11 on 6/29 then 14.5 on 6/30 so I lowered it too 40% chlorine is now at 13 on 7/2 so now I have lowered it to 30%. My CYA is between 65 and 70 and salt is 3200, PH went from 7.5 to 7.8 TA 190 I run my pump 24/7.
    Does this seem correct? I thought with the size of my pool I would have to run at a higher %. I do have an automatic pool cover and I think that has something to do with it because when its covered I don't think I lose much of the chemicals.
    30K gallon 20 X 40 IG vinyl built 8/2013, Hayward 1.0 hp super pump, 250,000 BTU Hayward heater, S244s Hayward Sand Filter w/side mount multi port valve, Hayward Aqua Rite Salt Chlorinator with Turbocell T-15 , Coverstar automatic pool cover with key switch, TF-100 test kit.
    Re: New SWG high chlorine
    The cover can make a gigantic difference. You probably actually have to watch out for that. If you adjust the percentage when the cover is on nearly all the time, it can be too low if you decide to leave the cover open for a couple of days.
    calespool's Avatar
    Dec 2013
    Savage, Minnesota
    21
    The cover is closed most of the time, I only open it when we are swimming usually about two hours a day and when I have the Polaris cleaning the pool.
    Jul 2013
    Waxahachie, Tx.
    442
    so why did you decided to run your pump 24/7? That seems a lot. I run mine 10 hours a day and plan on dropping it back to 8 hours. 4 hours mid morning and 4 hours late afternoon to early evening. I know my pool is smaller so we are not comparing apples to apples. I have been checking my FC in the mornings before the pump comes on and comparing it to the FC in the evenings way after it's off. Like a couple of hours after. FC has remained the same at my target level.
    SO my FC level/ SWG has been maintaining the FC throughout the day
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
    calespool's Avatar
    Dec 2013
    Savage, Minnesota
    21
    I turned the SWG to 20% on 7/4 and had pool open 12 hours yesterday and a couple hours today before I tested the chlorine at 10.5 today. Should I put in on 10%? Anyone else with this problem?
    As far as running the pump 24/7 if I ran it 50% the savings would be less then $250 for the 5 months it is open, so I am not really worried about that, my water has always been crystal clear so why change.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by calespool View Post
    $250 will buy a lot of beer and pool toys. Just sayin'.
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    I have an automatic cover as well as SWG. I find I can go quite low (sometimes down to 5% on the SWG, never over 30%) or entirely off for up to a week or so if the cover is on more than off. I am currently running my pump for 2 four hour shifts daily. I could cut that back more I suspect but it works well, and I'm enjoying keeping to pool open more to look at even if not actually swimming.
    Don't forget that even though we have covers, they do need to be opened routinely to let the pool "breath" a bit and release any outgasses sitting under that cover. Also, I tend to keep my CYA a skosh lower than normally recommended for SWGs as the cover cuts down on losses to sun. If *ever* I have an algae problem (**knock wood, never had one yet!**) I figure it will be easier to deal with then. My CYA goal level is 50ish.
    Jul 2013
    Waxahachie, Tx.
    442
    Wow wish I had an extra $250 to toss around. Not to mention the extra wear on the equipment. Anyway what ever works for you. Don't mess with success...right?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    If your SWG is running the whole time your pump is, then most likely your FC will always be high.
    The solution would be to put your SWG on a timer seperate from your pump. Then you could run your pump as long as you want, and your SWG will only make Chlorine as you require it to. Doing this will also greatly extend the life of the Salt Cell
    Divin Dave,
    May 2013
    Fort Lauderdale, FL
    423
    I had my looploc solid cover on all of May and June while my deck/porch was under construction. I had my SWG at 15% with pump at 6 hours a day and still had FC of 10-12! That's a good thing. No problem with lowering the percentage to the level you need. Personally, I'd cut your run time down to 4 hours AM and 4 hours PM and run the entire time it's being swam in. Save some power and wear/tear. You're not getting stuff in the pool with the cover on.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
