Thread: Pig Candy
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Pig Candy
    Simple, but yummy! Keep the heart attack meds handy...
    Take 3 lbs of thick sliced bacon and 2 - 3 lbs of dark brown sugar (must be dark brown). Cut bacon into thirds, seperate and put in full size disposable foil steam pan. Add sugar and get real messy. Sugar should be pressed into the bacon with no loose sugar left in the pan.
    Put on foil or cookie sheets with foil (note use foil or cleanup will be a real mess). Smoke for 1.5 - 2 hours at about 220-225. It can go hotter and faster if you need to. Use tongs to put into serving pan. Let cool slightly and watch the people go crazy.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Pig Candy
    My friend has a similar recipe...she takes the bacon and wraps it around the lil' smokies weiners, then tops it with the brown sugar sprinkled all over. Bake in the oven till the bacon is crispy and the sugar is all melted and goey.....OMG those are the best!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Pig Candy
    Geeze, I can hear arteries slamming shut just from reading the recipe!
    Sounds wonderful!
    You're done SLAMing when:
