Results 1 to 9 of 9
Thread: New Wall-Whale Wall Brush
    Jun 2014
    860
    Ok, call me a rube, a novice or just plain weird but I love the wall whale wall brush. For the past year I always used your basic wall brush for the pool. The way my pool is shaped there were always a few spots that I could not quit generate enough force on to feel like I was doing anything useful.
    I just purchased a Wall Whale and I'm hooked. Not only does the flap generate a nice bit of perpendicular force on the down stroke but it also lets me get those hard to reach areas. It also generates a lot if swirl and agitation in the water which is good if you like doing your wall brushing after a chemical addition. Side bonus is the little guys think the brush is cool and weird so I can get a little bit of child labor working on pool up-keep
    I paid ~ $25 for it at Ace which is super-pricey by standard wall brush prices. But heck, it works as advertised and saves my back a bit of stress.
    Here's a pic -
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: New Wall-Whale Wall Brush
    If you put the tail up all the way for maximum scrub, it's really easy to bend your pole.
    Butterfly's Avatar
    South Carolina
    10,045
    Yep, folks rave about that wall whale
    That's a good piece of info to have !
    You're done SLAMing when:
    Jun 2014
    860
    I have a pretty hefty telescoping pole, but I totally agree with you on that, it can generate quite a bit of force.
    I set the little plastic plug stop to the medium setting. Seems like plenty of force for me.
    38,305
    Love mine. All the nylon bristles were falling out of mine at the end of last year (can't remember how old it is). I just bought a mixed nylon/steel brush and unscrewed the tail and screwed it into my new brush ... you have to be sure you fine a similar looking brush so the screw holes line up.
    Jun 2014
    860
    Question - I have a peb-tek pool, should I be using a brush with steel bristled?
    I feel a little reticent to use steel bristles, seems like overkill to me. I feel like it would just rip the aggregate out.
    Is it just a wear resistance issue with steel vs nylon or is there something more to it?
    38,305
    You can use a full steel brush on plaster over a year old, so should be fine on the pebble as well. Like I said, I did not feel I needed a full steel and went with the mixed for a little more scrubbing power ... not that I brush very often
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    I bought the Wall Whale XL. It is a great brush and looks like it is a higher quality than all of the other brushes I've purchased, but my middle aged female body says I should have gotten the smaller brush.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Jun 2014
    860
    Quote Originally Posted by kcindc View Post
    Then you need some teenage kids to do the heavy work
    I made a deal with my neighbor's kids - they can use my pool as long as their parents give me verbal approval, I'm home to supervise AND they have to brush, skim and clean the skimmer basket when they're done. The quid pro quo helps keep my back from hurting
