Thread: How much of this stuff do I need
    Jul 2014
    wakeman,ohio
    3
    all of this is great info. but something I wonder about, that I havent seen. is how much of this stuff do I need to have for a new pool owner. My pool is going up thursday, so obviously i dont know what the water will be, but I would like to have on hand what I am going to need. So how much bleach is a good starting point, 1 gal. 5 gal. etc... How much baking soda, borax??? I know everyones water is different. and the test kit is on order.
    May 2013
    Bay City, Michigan
    283
    Re: How much of this stuff do I need
    Add your pool info to your signature...Size of pool plus gallons, type of pool, filter etc. Without that info, no one can really say, but expect to lose 2-4 PPM per day of chlorine. So, based on your pool size, figure out how much you would need to add to gain 2-4 FC per day and multiply by 7 and that's about how much you will use per week.
    Without knowing your pool size, or your results of your fill water...I can't even throw any numbers at you for borax and baking soda...but they do have other uses if you wanted a box of each on hand. On your new pool and fresh fill, you will certainly need stabilizer/conditioner on hand, again how much depends on gallons
    Signature
    Please put the following information in your signature.
    The size of your pool in gallons
    If your pool is an AG (above ground) or IG (in ground)
    If it's IG, tell us if it's vinyl, plaster/pebble, or fiberglass
    The type filter you have (sand, DE, cartridge)
    If you know, tell us the make and model of your pump and filter.
    List any other equipment you have: SWG, second pump, etc.
    Information in your signature will show up each time you post. Signatures need to fit on five lines. It is fine to put several bits of information on the same line.
    To change your profile or signature, see the Settings link, just below the Pool School button towards the top right of any page. Then select Edit Profile on the left, and you can edit your location. Click on Edit Signature to change your signature.
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Borax is an after thought. Don't consider it until you get FC, PH, TA, and CYA in line first.
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    You'll want enough CYA to bring your pool up to 30ppm -- you can use PoolMath to figure that out.
    For bleach, maybe start with enough for 10-20 ppm -- but don't add it all at once
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
