Thread: CYA test readings
    Jul 2013
    Waxahachie, Tx.
    448
    CYA test readings
    I know this has been covered a million times and I have read almost every post on the subject. Since the readings are subjective at best I just got back in town. My wife been doing an amazing job with the pool and testing.
    Her last CYA test was 60, 2 days ago. I tested this morning, bright full sun. At 60 and the dot starts disappearing, at 40 its no longer visible. What number should I go by?
    Richard
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Re: CYA test readings
    Sounds like 40. You want the dot to completely disappear.
    Also, it is best taken with back to sun (bright indirect sunlight).
    Apr 2014
    Sugar Land, Texas, United States
    42
    I am having the same debate so I decided to use my kids as 2nd opinion. I tested the CYA indoor and when I have doubt, I would ask the kids because sometime your concentrate on the dot stays on your brains even it is not there.
    Inground Plaster Pool, Cartridge Filter, Dolphin PRIMALX3, Hayward H400 Heater, Hayward Pump SPX3220X25Z2PE, 17500 Gallons with Spill Over Spa, Non-SWG, Sugar Land (Houston), TX 77478 USA
    38,470
    You should not do the test indoors. It should be outside in bright indirect light. Usually with the tube at your waist.
    You can get the CYA standard solution from tftestkits.net which is 50ppm and then experiment with what light is right for you.
