Page 1 of 6 1234 ... LastLast
Results 1 to 20 of 101
Thread: My 27' round sharkline venture install thread! AT LAST!!!!
    May 2014
    Nevada, TX
    238
    Okay so today is the day! Finally after one failed craigslist pool install attempt because of broken pieces and missing parts, I just went ahead and purchased a new sharkline venture and it is sitting in the yard where it's been for almost a week and finally today is the day installers arrive and put this beauty together for me! You can see in the picture the remains of our failed craigslist pool install where we actually never got the ground level we just through sand on top of dirt and attempted to pool at the pool around it. Major fail on our part. But alas the new pool build begins! So excited!
    In the picture you can also see 2 pilesof sand. The ugly pile is the sand that we used on the first pool yeah that's ugly sand! It was cushion sand and we were told that is what we we needed. The sand the pool installers had delivered it's very nice pretty and an amazing sand. Very fine, clean and soft sand! And yes that is my beloved Sharkline venture 27 foot round in boxes back there in the corner.
    So the bobcat worker is supposed to be here between 9 AM and 11 to start the day. When he's done he will leave and in a few hours later the installers will show up to put the pool together. I'll add pictures as the day goes along.
    Question: so I have my TF – 100 test kit but so far I have purchased no chemicals i.e. chlorine shock anything of the sort. Is there anything that you would recommend that I'm going to need to have on hand for certain that I can go and pick up prior to doing my first test? Or should I just wait until the pool is full I do a test and then go by what I need at
    27'x54" Sharkline Venture
    Hayward X-Stream Full-Flo 150 sq. ft. Cartridge Filter
    Matrix 1.5HP Dual Speed Pump
    Hayward Aqua Critter Automatic Above Ground Swimming Pool Vacuum Cleaner AR500Y
    TF-100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: My 27' round sharkline venture install thread! AT LAST!!!!
    Quote Originally Posted by starsfan33 View Post
    Question: so I have my TF – 100 test kit but so far I have purchased no chemicals i.e. chlorine shock anything of the sort. Is there anything that you would recommend that I'm going to need to have on hand for certain that I can go and pick up prior to doing my first test? Or should I just wait until the pool is full I do a test and then go by what I need at one time?
    Test your tap water. If the pH is high and the TA is over 100, it's a pretty sure bet you'll need some acid quick. And it keeps well. If pH is low and TA is low, then go the other route and grab some borax and baking soda.
    There won't be any CYA in the tap water, so don't bother testing it. You can hunt for the best price on stabilizer and bleach because you know you'll need some right away.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    You will need CYA also known as stabilizer or conditioner, and a few jugs of plain, unscented bleach. The rest can wait until after you have tested the water. If you want you can run the TA and CH tests on your fill water to get an idea of what those levels will be in your pool.You can use PoolMath
    to determine how much CYA you will need. When adding CYA start with 1/2 the recommended amount and re-test after a few days.
    Love TFP? Become a
    TFP Supporter!
    Waldog's Avatar
    May 2014
    Christmas, FL
    189
    Bring on the pictures!!! LOL
    Installed May 2014 - 16' x 48" Summer Escapes Pro Series Pool AG Vinyl (6,000 gal) - Intex 2650 Sand Filter - Christmas, FL
    May 2014
    Nevada, TX
    238
    Okay so here is my pH test. I have absolutely no clue what this means but here it is.
    TF-100 test kit
    Richard320's Avatar
    Jan 2010
    18,995
    It means the pH is high. You don't want pink, you don't want orange, you want peach.
    But for practical purposes, it means you'll need acid to adjust the pool when it's filled.
    May 2014
    Nevada, TX
    238
    Thanks Richard! This seems a bit overwhelming right now! LOL
    Now, you said TA? I assume that is Alkalinity test, correct? I see the solution in my test kit for that, but I see no instructions or color strips that I should compare it too. Am I missing something? (obviously I am! )
    EDIT: NEVER MIND! I JUST SEEN THE INSTRUCTIONS FOR THIS!
    TF-100 test kit
    May 2014
    Nevada, TX
    238
    Ta = 120
    TF-100 test kit
    Casey's Avatar
    SW PA
    10,438
    High TA, high pH. Once you get everything set up, you can work on bringing your TA down as shown in Pool School.
    I want more pics!!!
    Waldog's Avatar
    May 2014
    Christmas, FL
    189
    The masses demand pics!!! Are they setting up the pool yet!!!?
    May 2014
    Nevada, TX
    238
    the bobcat worker still isn't here. im starting to worry. im going to give them about 15 more minutes and then start calling! I was told between 9am and 11...its 10:25am now.
    edit: So I just called, they are running behind. Should be here within the hour (I hope!.
    anxiously waiting!
    TF-100 test kit
    Casey's Avatar
    SW PA
    10,438
    I'm anxiously awaiting too!!! What liner did you get?
    May 2014
    Nevada, TX
    238
    And an attempt to appease the masses demand for photos as I await the installers I am unpacking the pool to speed them up when they finally arrive! LOL so for your viewing pleasure may I present to you… The uprights!!!
    TF-100 test kit
    May 2014
    Nevada, TX
    238
    Here is the liner I got. I'm less than thrilled with this liner. Originally it was the one I was looking. Then I changed my mind and I ordered a different one. The one I ordered they could not get printed and delivered in time and they have this one in stock so they made me a deal to take this one instead. And then I keep looking at your liner and I love it but it was not available on the 27' from pool supply world. In the end I got this one because it could get here in time for my installtoday. I don't hate the liner but I do prefer others more than this. This point it is what it is and I'm just happy to have my pool going up today. I hope. Where are those guys? LOL
    TF-100 test kit
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,476
    I like that liner. It has a classic look about it!
    Love the pic of the uprights. I hope they will soon be in the upright position!
    Kim
    May 2014
    Nevada, TX
    238
    Still no installers here. But here is some more unpacking pictures!
    Bottom rails and stabilizer rails!
    I think the installers missed the best time of day to install. Was nice and cool off there earlier is heating up quite a bit now! And here is my favorite thing so far! I really hope that this turns out to be a good and filter I originally was going with the Pentair and it was out of stock so I went with this combo from Hayward. It looks really nice.
    TF-100 test kit
    Jul 2012
    Tallahassee, FL
    30,476
    Do you have turn off valves for both the places the plumbing comes out of the pool? Are you going to hard plumb it?
    I just do not understand them saying "Let the water drain to below the skimmer to open filter". That is a large waste of time and water!
    I also have valves for my waste and backwash (which you do not have but.....). I love valves LOL
    When you can I would think about getting a back up filter cart. so you can just throw it in and get the pump running asap. You can than clean your filter completely because you will not be rushing.
    Kim
    May 2014
    Nevada, TX
    238
    Not sure about the valves I haven't looked that closely at it yet. We do intend to go back later and hard plum the pump ourselves.
    TF-100 test kit
    May 2014
    Nevada, TX
    238
    Still no installers starting to get concerned. :/
    TF-100 test kit
  20. Back To Top    #20
    Jul 2012
    Tallahassee, FL
    30,476
    There are times I really think they do not own clocks/watches/alarms! It is quite frustration but.............it is what it is and best to have a smile on your face and a ice cold drink for them when they do get there!
    Kim
