I just got done with the slamming process started on 6-20-14 started with fc of about 1 and cya at around 80. did some drains & refills to get the cya down and ended up putting in 93 gallons of liquid shock during the slam! I finally lost 0 fc overnight and pool is looking good! here is where its at now
fc 11.5
cc 0
ph 8.0
ta 190
cya 50
pool is 38,000 gallon vinyl lined with sand filter.
question 1 i was going to try to keep my fc at around 10 does that sound about right?
question 2 My ph is a little high & my ta seems high. should I try to get them down? and if so whats the best method of getting them down. can I get them both down together or do I need to lower 1 to lower the other. i did read up on them in pool school just a little confused.
I will say that in the middle of the slam after adding so much bleach i was beginning to question my sanity! but glad i stuck it out!
thanks again for everyones help through this process
fc 11.5
cc 0
ph 8.0
ta 190
cya 50
