Results 1 to 10 of 10
Thread: Just fisnished slamming have a few questions
    Jul 2013
    Greenwood, IN
    35
    I just got done with the slamming process started on 6-20-14 started with fc of about 1 and cya at around 80. did some drains & refills to get the cya down and ended up putting in 93 gallons of liquid shock during the slam! I finally lost 0 fc overnight and pool is looking good! here is where its at now
    fc 11.5
    cc 0
    ph 8.0
    ta 190
    cya 50
    pool is 38,000 gallon vinyl lined with sand filter.
    question 1 i was going to try to keep my fc at around 10 does that sound about right?
    question 2 My ph is a little high & my ta seems high. should I try to get them down? and if so whats the best method of getting them down. can I get them both down together or do I need to lower 1 to lower the other. i did read up on them in pool school just a little confused.
    I will say that in the middle of the slam after adding so much bleach i was beginning to question my sanity! but glad i stuck it out!
    thanks again for everyones help through this process
    38,000 gallon vinyl lined in ground pool with diving deep end.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Just fisnished slamming have a few questions
    As soon as FC drops below 10, use muriatic acid and lower the pH to about 7.4.
    With 50 CYA, keep FC between 4 and 8, and ever below 4.
    Don't worry about doing anything with the TA for now . Later, if your pH is annoying you because it is climbing fast/often then you could address the TA.
    Good work on the SLAM Got a pic?
    You're done SLAMing when:
    May 2014
    Georgia, USA
    19
    Because I've recently tried to perform a SLAM also for the first time (and unsuccessfully based on OCLT), am I reading that correctly that it took a week and a half and nearly 100 gals of bleach?
    IGVL (Liner ~10 yrs old), 25,000 gal (18x36 ft, 8 ft deep end), 2 drains, 3 returns + Polaris return, 2 Hayward skimmers, AquaLogic Control Unit, T-15 Salt cell, Hayward Super Pump 1 hp, Polaris Pressure Cleaner (280) w/ Booster Pump, Hayward S244T Sand Filter, TFPC method with TF-100 Test Kit + Speedstir
    Jul 2013
    Greenwood, IN
    35
    Ill post up a pic tonight when i get home. how much muruatic acid should i put in to lower the ph?
    sorry, i keep forgetting to use pool math, if I did my calculations right add 68 oz muratic acid. do you just pour the acid into the pool or into the skimmer? also how soon can you swim after adding acid? and how long will it take before i can res test ph
    Butterfly's Avatar
    South Carolina
    10,045
    You need to use the PoolMath calculator. There is link at the top of each page in the menu bar.
    You will need to add pool gallons at top, and be sure to add TA in the now column, since it does effect pH.
    Post back if you want someone to confirm your calcs and doses.
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Quote Originally Posted by Jd-underdog View Post
    Pour acid slowly in front of a return. Brush area after addition to mix as it is heavier than water and tends to sink. Wait approx half hour to test pH.
    S1ngram's Avatar
    Jun 2014
    Chrisman, Illinois (East Central Illinois)
    304
    I started my slam on the 20th also. I'm still not done. I have used 63 gallons so far. I may only use 1-2 gallons per day at this point. Early on, I used a lot every day.
    27' round Seaspray Evolution, AG, 17,100 gallons, Pump: Hayward Power-Flo Matrix Dual Speed 1.5 hp, Filter: Hayward Pro Series High Rate Sand Filter, June 18, 2014, Kreepy Krauley Lil Shark, TF-100 test kit, Intex Krystal Clear Saltwater System
    Jul 2013
    Greenwood, IN
    35
    one more question. I pulled my light about a week ago its just been sitting on the concrete out of the water. with it being out of the water for over a week if it did have algae on it would it be dead now or should i clean it? and if so what should i clean it with?
    thanks
    May 2014
    584
    Scrub with a solution of 50% household bleach and 50% water.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Abigail K View Post
    Yep, that will kill anything!
