Thread: Advice needed - Wrinkle in liner.
    Hey everyone,
    I need your advice. To make a long story short I ended up getting water behind my liner and it started to float. I used my dry well to pump out the water, now my liner has a few wrinkles in it. Can I get them out manually or does my liner need to be reset? Your advice would be greatly appreciated.
    Cheers!
    Before I pumped the water out from behind the liner.
    The wrinkles from pumping the water out.
    Mike59's Avatar
    Jun 2014
    Lancaster, PA
    81
    Re: Advice needed - Wrinkle in liner.
    I am interested in hearing others advice. I got wrinkles a few years back over the winter when the ground heaved and settled. My pool guy said that can be common. He installed a brand new liner, and a week later after some heavy rains the liner wrinkled. He said there is nothing you can do if you have ground water. He said there was nothing to worry about as far as the liner tearing though...it was all cosmetic. He said only way to fix was drain pool and redo it.
    Does that sound right to others?
    Good luck Judge and thanks for asking the question.
    16K gal, IG Vinyl, Hayward DE Filter EC-65, 3/4 HP pump, Raypak R266A Gas Heater, Hayward Chlorine Feeder (Retired), Dolphin cleaner. K-2006 w/ Speedstir.
    Pool 18yrs - Liner 14 yrs
