Thread: Borates Don't Drop?
    Nov 2013
    Los Altos, CA
    30
    Borates Don't Drop?
    All,
    I added borate to my pool back in April. Overshot my goal slightly and hit 50ppm. Not too high based on what I've read, so I was thinking I'll just wait for it to drop due to splash out, evaporation, etc. However, I still get a reading of 50 ppm. I will admit I find the borate strip test hard to read reliably, but am pretty sure I'm reading it correctly. By comparison my CYA reading have dropped over the same time from 75ppm to 60ppm. Am I missing something here?
    Thanks !
    Free Form IG Pool with overflow connected Spa. 28K gal. Finished Sept. 2013.
    Wet Edge Primera Stone (Tahoe Coast)
    Intelliflo VS Pump. Paramount Cleaning System. IntelliClor IC40 SWG. Sta-Rite System 3 Cartridge Filter.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: Borates Don't Drop?
    I am assuming that you added water after the splashout? I would think your borates have dropped, but with the accuracy of borate tests, your similar readings are not uncommon. How are you testing? Add another 10 ppm if you wish. There is no harm. You know you were at 50 so 10 ppm should have you below 60 (since splashout), so you would still be fine.
    Out of curiosity, what was your initial target? I'm just wondering why you targeted below 50.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Nov 2013
    Los Altos, CA
    30
    Sorry for the late reply. I was traveling for the holidays. My target was 40ppm based on my reading here, but I wasn't concerned with 50ppm. Just higher than my calculations indicated I should get to
    I have an auto-fill so with splashout I would have expected the borate ppm to drop. I'm using the Lamott borate test strip recommended on this site. I find them hard to read but seem to get consistent readings.
