Results 1 to 7 of 7
Thread: should I be concern seeing some small spots of green algae?
    Apr 2014
    Sugar Land, Texas, United States
    42
    I am loosing like 3ppm of FC during the day, temperature in Houston is around 94F. Is this normal? it means that I need to add 77 Fl Oz of bleach per day since my current reading are:
    FC 5 <-- need to maintain at 5
    Combine Chlorine 0
    PH 7.8
    TA 80
    CYA 40
    Borates 80
    Water Temp 90
    I am going to check the chlorine lost tonight but just curious the chlorine lost during the day at that rate is normal. I also noticed that my PH does go up quite frequently like current 7.8, it will be around 8 in a week.
    Inground Plaster Pool, Cartridge Filter, Dolphin PRIMALX3, Hayward H400 Heater, Hayward Pump SPX3220X25Z2PE, 17500 Gallons with Spill Over Spa, Non-SWG, Sugar Land (Houston), TX 77478 USA
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Re: should I be concern seeing some small spots of green algae?
    Small spot of green? You should SLAM. After that, try raising your cya to 50.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    How small is small? an inch or so along a grout line just at the water level is nothing to get excited about. Just scrub it off with a brush and slosh some bleach that way. A few square inches on the wall below the surface is worth getting excited about. 3 ppm per day can rapidly turn to 5 or 6 and by then, your pool is a swamp. So in that case, the Shock Level And Maintain process is called for.
    Incidently, patches of algae indicate poor circulation in that area. Regular brushing helps with that.
    7.8 to 8 in a week sounds pretty mild for pH rise to me.
    Apr 2014
    42
    They are very small, like a chicken pox size and only certain spots. I've tested the overnight lost and it is less than 1 so FC seems to be fine.
    Woodyp, why I need to raise the CYA? I thought 30-50 is ideal? Just curious because raising the CYA means I need higher FC correct? So if I have high FC, it means I will loose less during the day?
    Richard320's Avatar
    Jan 2010
    18,984
    Quote Originally Posted by sangweb View Post
    Little chicken pox could be black algae. It's tough to eliminate. Use the search box to learn about it.
    Apr 2014
    42
    They looks pretty green to me and can be easily scrub off with the metal brush but I'll check out your suggestion to see what cause. Thanks.
    Apr 2010
    East Texas
    9,581
    If you're only losing 3 ppm daily of FC, disregard raising your cya.
