Page 1 of 3 123 LastLast
Results 1 to 20 of 43
Thread: CYA out of control...among other things
    Jul 2014
    Prospect Heights, IL (NW Chicago)
    64
    Hello everyone. I'm new around here having just recently given in and sold my condo in the city for a big fancy house in the burbs with a pool.
    Pool specs are (need to set my sig sorry) ~36.5K gallons IG gunnite with cartridge filter.
    Well to no great surprise, the previous owner did all the maintenance himself. That's resulted in me buying a brand new filter (both he had were garbage) and some new temp sensors and other misc equipment. Then for the water his efforts seemingly consisted of nothing but trichlor pucks, dichlor shocks before parties, and soda ash to keep the PH up. Consequently the CYA (and TA) is ridiculous. I estimate it to be as high as 450 or even more...I haven't yet managed to dilute the water enough to ever actually get a reading.
    Does anyone know a company in the Chicago area that does RO for pools? That seems to be my only way out of this mess. Otherwise I may just wait until next spring and have water trucked in for a massive replacement. I mean it almost seems ridiculous how messed up this thing is for it to be crystal clear and looking like everything is hunky dorey.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: CYA out of control...among other things
    Welcome to TFP!
    As far as I know, RO is only available in the extreme SW. If you can make it through this season, you'll usually lose a lot of CYA over the winter.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Wow, if we go with CYA 450 that means FC should be
    Minimum 33.75
    Target 51.75
    Shock 180
    Numbers calculated from ChemGeek's calculations
    A reasonable approximation to the above table is the following:
    .... "Min FC" is 7.5% of the CYA level
    .... "Target FC" is 11.5% of the CYA level
    .... "Yel/Mstrd Min" is 15% of the CYA level
    .... "Shock FC" is 40% of the CYA level
    .... "Yel/MstrdShock" is 60% of the CYA level.
    Since chlorine is more effective at lower pH, it is normally recommended to lower the pH before shocking at a high FC level, especially for yellow/mustard algae where lowering the pH to 7.2 before shocking at the above levels is best (and remember that the pH test will not be valid during shocking due to high FC levels).
    Support the site
    Jul 2014
    64
    Quote Originally Posted by JohnT View Post
    Yea that would be nice but I'm kind of worried about now. I don't know much about this gunite stuff...is it as susceptible as plaster to corrosion/scaling? I don't want to get into an even bigger mess. Sometimes the CSI number on poolmath scares the **** out of me (or even shows NaN), but I suspect a lot of these things break down when numbers are this crazy.
    Quote Originally Posted by tim5055 View Post
    Minimum 33.75
    Target 51.75
    Shock 180
    I know right! FC has been under 10 for like 3 weeks and water is crystal clear. All signs point to me not being able to do the CYA test correctly but I'm fairly confident that's not true. I did a dilution today of 2 parts pool to 3 parts pure water (from RO drinking water inside) and still the black dot was long gone well before I even got up to the 100 line on the comparator. It's nuts! I need to dilute more and at least try to get a reading but also I think at this point the CYA is essentially "way too freaking much". =(
    May 2014
    Franklin, NC
    9,187
    Quote Originally Posted by Vyrolan View Post
    No, always use one part pool water, so
    Pool water......Tap or distilled water.........Multiply result by**
    ....1...................1................................2
    ....1...................2................................3
    ....1...................4................................5
    You may not be as high as you think, but still too high
    **Chart by JamesW in a 2012 post
    Support the site
    Jul 2014
    64
    I don't have any great way to measure volumes accurately...so I did up to 10ml on my comparator in pool and filled to 25ml with water from our RO...so 2:3...so actual number should be 5/2=2.5 times measured result. But I couldn't accurately measure so it was still way over 100...
    May 2014
    Franklin, NC
    9,187
    Kitchen measuring cups is what I used when mine was over 200. One cup pool water, one cup tap water mixed in a glass. Then to the first line in the CYA bottle.
    If it's still too high one cup pool water, two cups tap water mixed in a glass. Then to the first line in the CYA bottle.
    Support the site
    Jul 2014
    64
    Good idea. I'll see if we have the kitchen unpacked enough to find them. =p I'll probably try a 1:4 because clearly my 2:3 (1:2.5) wasn't even close. Even when I do get a pseudo correct reading, it's still going to just be "that's way too high". =p
    Jul 2014
    64
    As I've been thinking more about this...maybe some water replacement to lower the CYA could be a good idea here...it would hurt me in the CH department (pool is already at 675 CH and fill water from well is even higher)...but that seems arguably better than massive CYA. Unfortunately with the cartridge filter I don't even know how to go about draining short of siphoning with a garden hose. The pool equipment pad is not in the greatest location (IMHO) so doing a huge drain at the filter with the cartridge removed is a bad idea. Any recommendations for a little transfer pump I could use to pull water out? Even better if it's one I could adapt the suction side to run a vacuum as a way to vac to waste.
    Jul 2014
    64
    So I can get trucks of ~6000 gallons for $300... So for $900 I could replace roughly half the water...that would probably help me a lot with CH in addition to obviously with CYA. Maybe do that and then let the over-the-winter CYA reduction and closing/opening water replacement make it completely right for next season... Hmm...really need to get a reasonable grasp on what the CYA level really is...must dilute further tonight!
    40x20 IG gunite (~36K gallon). 6' attached spa with spillover. AquaLink RS OneTouch + SpaLink + iAquaLink 2.0
    450 sqft Sta-Rite cartridge filter, Sta-Rite single speed pumps (main, spa jets, booster)
    Coverstar Auto Cover, Polaris 280 cleaner, Taylor K-2006
    May 2014
    Franklin, NC
    9,187
    If you are going to go this route, do it all at once - Drain the pool half way then add the three trucks of water. If you do it in 3 separate operations it will not give you the 50% reduction, but a smaller % (if my math is right, with your pool each truck load would be a 16% reduction.
    So, if we say your CYA is 400 for arguments sake,
    3 truck loads done at once will drop you to 200
    Truck loads done separately will yield you the following
    Truck 1 Start 400 less 64 (16%) 336
    Truck 2 Start 336 less 53 (16%) 283
    Truck 3 Start 283 less 45 (16%) 238
    Truck 4 Start 238 less 38 (16%) 200
    Someone check my math, but it would appear to get 50% separately you need 4 trucks.
    Please remember, high water tables and some other conditions may preclude you from draining too much from the pool.
    Support the site
    Jul 2014
    64
    Oh that would definitely be my plan...just let them do it all in one go....they can apparently dump the 6000 gallons in like 10 minutes....so it could be back up in like 30 minutes....but obviously it would take me like 18 hours to get it drained that low. =(
    Yea that was my biggest concern....draining 18000 gallons would leave my shallow end at about 6" (3.5' shallow end, 8.5' deep end)... I'm not sure if I can go that far or if it's safe or what...
    Smykowski's Avatar
    Sep 2011
    3,065
    You guys are on a well in Prospect Heights? I thought all of the suburbs, with the exception of the far north suburbs, were on municipal water.
    Jul 2014
    64
    Quote Originally Posted by Smykowski View Post
    We have well for input and municipal sewer for output. Apparently all of Prospect Heights is like that...no municipal water exists. In many ways well+sewer is the best of both worlds...but the well is a negative when it comes to the pool. =(
    Smykowski's Avatar
    Sep 2011
    3,065
    Yeah, that does put you in a bind. For the future, you can harvest rainwater from your roof for CYA/CH-free top offs, but I know that doesn't help now.
    Jul 2014
    64
    ...you can harvest rainwater from your roof for CYA/CH-free top offs...
    I've read some place (maybe on this site?) that rainwater from the roof is not a good idea. It was something about the shingles and other roofing materials can put some stuff in the water that make it not good/safe/whatever for pool use.
    Smykowski's Avatar
    Sep 2011
    3,065
    I put a nylon at the end of the tubing as a screen/filter, but that's it.
    30,426
    Rainwater is a very viable alternative given your pool conditions.
    ANY CYA above about 200 I would consider an UNMANAGEABLE pool and would make no attempt whatsoever to salvage it. Drain and refill is the only thing that makes sense,
    Jul 2014
    64
    That makes sense...I'll probably look to do that after this weekend with family visiting. How do I know how far I can drain? I'd rather not get into a series of small drain and refills with ever-diminishing returns each time.
    Also...anyone have advice for convincing the wife that we should spend ~$1000 to drain and refill half the pool when it "looks" like nothing is wrong...I try to tell her that our clear beautiful water actually has bad levels of these things that don't make it unsafe to swim but do make it a pain to maintain...but she doesn't really care about such things. =p
  20. Back To Top    #20
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Well, with a CYA that high, the water won't "look" good for very long.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
