Thread: Installing a DE Filter
    Jul 2014
    Boston
    12
    I ordered a Hayward DE pro-grid 36 and plan on installing it myself later this week. The pool is currently closed. I was wondering if I can install the new filter first and then open it or if I need to open it with the old filter, get it reasonably clean and then install the new filter.
    One of the things that concerns me is that the manual says to add the DE through the skimmer initially. That kind of means I'll be adding it along with dirty green water.
    I tried checking out some YouTube vids but in every tutorial about changing a filter the water is already sparkling.
    I'd rather install the new filter before opening if possible.
    Thanks.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Installing a DE Filter
    Welcome to TFP!
    What kind of filter do you have now? DE can be a pain when the water is really dirty.
    Jul 2014
    Boston
    12
    I have a no name sand filter. There aren't any shut off valves between the pump and the filter or the pool and the filter. If the pool were up and running, is the pool water going to come out when I disconnect the sand filter? The pool is in ground and the pump and filter are obviously above the pool.
    SW Indiana
    9,199
    Quote Originally Posted by SteinwayD View Post
    Only the water in the filter will need to be drained. I think opening the pool and at least getting the algae killed and partially cleared before installing the DE filter would be the best course.
