Thread: Losing water through backwash hose
    Jul 2014
    POINTE-CALUMET
    3
    I'm losing water through the backwash hose even if the handle is on filter. There is also a little bit of water around the handle. I'm thinking, I may need to change the gasket of the filter. If my model of filter can be changed. I've never done this. So I really need step by step instructions please. Thank you
    15 feet round, above ground pool, sand filter (jacuzzi L 192c-7c) with hayward motor
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Re: Losing water through backwash hose
    You can plug the hoses with winterizing plugs, or a cork, or maybe even try ramming a carrot in the openings to plug them.
    If you look on youtube, there are lots and lots of videos that show how to replace a spider gasket.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    Take the old one one, put the new one in and lube it,
    Jul 2014
    POINTE-CALUMET
    3
    Thank you Richard320, I think that will work for the rest of the summer and in the fall when I close the pool I can open the filter and change it. I'll check out youtube. ty
