Thread: Pump recommendation
    May 2014
    St. Louis, MO
    3
    Pump recommendation
    I have a Hayward TriStar 1.5 HP pump that keeps cycling on and off, and is running very hot.
    I was thinking of replacing the motor and seals, which would cost around $350 in parts from amazon.
    Should I repair my pump, or would this be a good time to replace the pump with a 2-speed or variable speed pump.
    Any troubleshooting advice, or pump recommendations would be appreciated.
    I live in Missouri where rates are 12 cents.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Pump recommendation
    you can just replace the motor with a 2-speed.
