Results 1 to 17 of 17
Thread: Do I need to make adjustments?
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    Current numbers:
    FC. 2.5
    CC. .5 (could this be from 50 june bugs in the skimmer?)
    PH. 7.8
    TA. 90
    CH. 240
    CYA. 50
    Water temp 88 and sparkly.
    Added 75oz for a target of 6. Will recheck in 30 minutes.
    I know my minimum should be 4. But in this heat I can not, so far, hold that. Pool is open to full sun all day. Should I try to raise CYA? Is the level of FC that CYA protects a particular amount? If I raised the CYA , my target and minimum would be higher but I don't know if it would still protect down to the minimum.
    Or should I just shut up and keep swimming?
    14.3k, 3 1/2-5 1/2, IG, Pebble Wet Edge Northshore Tahoe, Jandy 4 cartridge, Jandy 2hp variable, Pentair 320 inline chlorinator fed by a Stenner, Polaris 280, K-2006 test kit, Built 9/13
    Fill water: TA=90, PH=70, CH=90
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    Re: Do I need to make adjustments?
    After 35 minutes
    FC. 7.5
    So I know my bleach is good
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    Just curious, why is your target 6 rather than 8 if you're having trouble staying above 4 ? PoolMath says the FC range for 50 CYA is 4-8. If you raise to 8 I wouldn't expect it to drop below 4 by the end of the day unless something is living in your pool and not paying rent.
    I'll leave advise about raising CYA over 50 to folks from Texas (and Arizona and California) where they have real sun
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    Cya/FC chart for 50 cya shows 4 - 6. Am i missing something?
    38,251
    You have to raise it high enough to never drop below the minimum ... that is the most important. I guess we will find out tomorrow if 6ppm is high enough for you.
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    It won't be, I've been targeting 6 for a couple of weeks. After reading Bridgman's post, I went back to pool math. I have never noticed the blue section at the bottom for suggested FC. Now I know where he got the 4-8. I'm gonna give that a try. Is there a correlation problem between cya chart and pool math?
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    I added another 11oz to get to target of 8. Now, we will see what happens tomorrow. Bridgman, if this works, you get my vote for "THE MAN" . I would buy you a beer if this is the secret if you weren't so far away. How close are you to Calgary?
    bridgman's Avatar
    Mar 2014
    461
    Quote Originally Posted by Reddogdan View Post
    Nope, you're right. Chlorine/CYA chart in PoolSchool => Handy Reference says 4-6, PoolMath says 4-8.
    Probably best if you read it as "4-<whatever it takes so that FC does not drop below 4 by the next time you regularly test>"
    I'm 3,597 km away going through the US and taking the Interstate (seems to be the fastest route). ~65 km north-east of Toronto.
    If it works I'll raise a beer towards Calgary tomorrow evening
    EDIT -- oops, you're nowhere near Calgary either... so will raise in the general direction of Texas instead.
    Butterfly's Avatar
    South Carolina
    10,045
    After 35 minutes
    FC. 7.5
    or the pool is smaller than calculated gallons?
    I agree that you should shoot for a FC target of 8.
    Tonight, I suggest that you do an OCLT to make sure organics are not a problem.
    or, as Bridgman said,
    ....... unless something is living in your pool and not paying rent.
    You're done SLAMing when:
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    Thanks for the suggestion Butterfly, but for Texas, I'm thinking now that the 4-8 would be a better range. That and I have to be at work at 4am. If I'm below 4 tomorrow, then I'll do another OCLT for the fun of it. As to my other question, could 50 dead June bugs in the skimmer cause the .5 cc? It's actually probably less since the tube smells the drops and goes back clear.
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    Yay, I held my minimum of 4
    38,251
    Bump it back up to 7-8ppm and check again tomorrow.
    Butterfly's Avatar
    South Carolina
    10,045
    The june bugs may have created just enough CC for your tube to 'smell' it, then it dissipated
    It is not unusual for a pool to test positive for CC occasionally and during the day the sun could burn it off just as fast.
    Happy Swims
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    Held at FC. 4.5 today target was 8. So for me that's, 75oz 8.25 bleach. Should I think about raising my CYA to 60 and hope I can add less bleach per day? Still, it's only about $2.00 a day in bleach. Suggestions?
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    Still staying at FC 4.5 thru the afternoon. I guess my pool is gonna be a 3.5 ppm vampire.
    Butterfly's Avatar
    South Carolina
    10,045
    Well, if you have a lot of sun, you might want to bump the CYA up to 55ish. Adjust FC accordingly and try that for a while.
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    I have full sun until 4:00pm
