Thread: Salt Water Stains
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Salt Water Stains
    I started seeing salt water stains on tiles above the water, is this normal? If not how to correct, or clean off....Thank you
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Salt Water Stains
    Can you post a pic?
    You're done SLAMing when:
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Quote Originally Posted by Butterfly View Post
    Can you post a pic?
    Here is one they are a white discoloration on the tiles...
    Autopilot SWG
    That is mostly calcium, and happens with or without salt in the water. You can remove it with a dilute muriatic acid solution.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Quote Originally Posted by JasonLion View Post
    acid removed the calcium stain, but turned my grout around tiles brown....any ideas how to remove brown stains....I tried bleach didn't touch it...
    I used 1 cup acid to 4 cups water...
    Thanks
    Autopilot SWG
