Thread: What went wrong?????
    priester68's Avatar
    May 2014
    Natchez, MS
    7
    Question What went wrong?????
    I just got the pool up and running. Joined this web site. Got some info. Pool was doing great, took the family to New Orleans for 3 days, and came back to this! What happened and what can I do to fix it? Really cloudy but you can see the bottom when standing by pool.
    Also, I don't know how to turn the photo so you can see it straight.
    My pool info (according to pool box and paperwork)
    Pool - Intex round ultra frame pool 18x48 (Wal Mart) 6,423 gallons
    Pump - Krystal Clear Model 635T 1500gph w/ filter cartridge size 8" x 4.13"
    Aqua Chem Floater w/ 3" chlorinte tablets. Capacity - 4
    Installed and filled on 5/25/2014
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Re: What went wrong?????
    Yup, pools are a living being. They must be fed everyday (chlorine) or bad things happen.
    You need to SLAM. In your warm climate if you don't get on it you won't see the bottom for long.
    Support the site
    38,521
    Welcome to TFP!!!
    Clearly your FC level dropped too low for your CYA level ... as shown in the FC/CYA Chart. The floater was not likely adding enough FC and the CYA from the tablets is building up. Please check out the How to Chlorinate Your Pool article.
    Can you post up a full set of test results? Hopefully using one of the Recommended Test Kits.
    The solution is following the ShockLevelAndMAINTAIN Process, which requires the FAS-DPD chlorine test.
    priester68's Avatar
    May 2014
    Natchez, MS
    7
    Thanks. I'm going to get on that ASAP. Kinda confusing but I'll be back with questions I'm sure.
