Thread: Stroker, Large project , Florida panhandle
    Jun 2014
    Pensacola, Florida
    2
    Hi All, glad to be here. Been sneaking around the site for a couple of days and seems like a great place to learn.
    We recently began remodeling my inlaws home, property, and "the Lilly Pond". That is what the pool has been since about 2002. Some things on the I would like to have list since it they have to be replaced are, a variable speed pump, SWG system, and will probably need to replace the sand filtration system. I could use some assistance with putting together a system that will work together as a unit. She is going to have to have a little repair work on the steps, (couple of holes and a hairline crack in the wall.)
    Would apreciate your suggestions.
    Thanks
    Pool Size - 13,500 gallons In Ground Pool, Plaster/Gunnite
    Currently has old sand filter, Pump - single speed worn out, 1.5" Pipes
    Date of Build: Early 70's ? Pyramids? Need Water Test KIt
    Other options: Holes in steps hairline crack in wall.
    38,475
    Re: Stroker, Large project , Florida panhandle
    Welcome to TFP!!!
    What is your power cost down there? A 2-speed pump may make more sense ... or one of the smaller VS pumps, certainly no need for the big 3+HP VS pumps.
    Size a SWG system for 1.5-3 times the size of your pool. So at least a 25k cell.
    For a sand filter, I would suggest at least a 21" diameter for that size pool, bigger is usually better.
    Jun 2014
    Pensacola, Florida
    2
    Thanks for the welcome and info Jason!
    My electric rate is 13.5 per kwh. I am thinking since I have to purchase new equipment anyway and plan to stay put, that efficiency should be at the top of the list. Assuming that I go with a vs pump, and SWG system, will one type of filtration system perform better than others? I don't look forward to the expense, but the pool also needs to be refinished.
    Casey's Avatar
    SW PA
    10,457
    Welcome to TFP Stroker96!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    HI Stroker,
    the different filters all have their plus and minuses.
    here is a link to TFPC comparison between the differnt types.
    http://www.troublefreepool.com/conte...ter-comparison
    Divin Dave,
