Results 1 to 8 of 8
Thread: DEL Ozone MCD-50 or other Ozone products
    Mar 2014
    Arroyo Grande/California
    32
    I was wondering if anyone has tried one of the ozone generators and if they are worth the 130 bucks to install?
    38,371
    Re: DEL Ozone MCD-50 or other Ozone products
    We do not recommend ozone for use in residential outdoor pools ... they do not provide any real benefit that chlorine will not do alone.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Like Jason said, there tends to be very little if any benefit to ozone systems in typical low bather load outdoor residential pools, although they do potentially have a place in high load, therapy, and some indoor pools and hot tubs.
    Donldson's Avatar
    NW Ohio
    2,904
    I will 3rd Jason and Isaac, not worthwhile in most residential outdoor pools.
    Just about any "chlorine alternative" is discouraged here. Most of them still require some chlorine, bromine, or baquacil to be used as they are not a true sanitizer. Some provide little to no benefit. Others, like copper-silver mineral systems, can offer some sanitizing but fall far short of chlorine's kill rates and have negative side effects.
    I have been around the site long enough to know that if they do someday come out with an alternative that is cost effective and as efficient as chlorine (with numbers backed up with research and real science) that it will be added to the list of recommended sanitizers. Until then, and even after then, chlorine alone provides great sanitization at a low cost with minimal negative effects.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Isaac-1's Avatar
    SW Louisiana
    6,711
    To follow up on my previous comment, contrary to much of the advertising hype ozonators will actually increase not decrease chlorine consumption in a well balanced typical outdoor residential pool. Chlorine consumption reduction only occurs in pools that we would consider out of balance due to high CC levels, etc. In the right situation, their strong point is their ability to help break down combined chlorine and provide supplimental oxidation in pools and tubs prone to build up of combined chlorine products, such as those with low levels of UV exposure, elevated temperatures, and high levels of bather waste products, and this is not the case with most outdoor residential pools.
    Mar 2014
    32
    I can see that ozone may not be right for me-- I did have a outdoor, in ground spa, so I was wondering about your statement; "...and some indoor pools and hot tubs."
    A stand alone spa can make use of ozone, particularly if you are using bromine as the sanitizer. An outdoor spa connected to the pool can not.
    Mar 2014
    32
    So, it may be right for me to pay 135$, as I have a stand alone spa, which is drained and I have not decided on a sanitizer?
