Thread: Hayward SwimClear Cxx30 vs. Cxx25
    Diver's Avatar
    May 2011
    South of Boston
    450
    What is the difference between these two model lines? For example SwimClear C4030 and C4025? The seem to have identical dimensions, filtering surface and so on. Is one of them newer version of another?
    The only difference that I could spot is in flow/head graphs (Cxx25 left, Cxx30 right). Looks like Cxx25 is less restrictive.
    26K In-ground Vinyl Pool | Hayward DE4820/SP0710XR50 filter | 1.125 HP Dual Speed Hayward Super Pump | Aquasol Solar
    38,305
    Re: Hayward SwimClear Cxx30 vs. Cxx25
    Looks like there are some internal differences in the manifolds if you look at the part break down in the 2 manuals.
    The 25 appear to have the flow exit the cartridges on the bottom, but the 30 has the water exit from the top of the cartridges.
    Diver's Avatar
    May 2011
    South of Boston
    450
    Hayward confirmed that the only significant difference is that new version (Cxx30) has manifold on top vs on the bottom for Cxx25.
