Results 1 to 8 of 8
Thread: How much Clorine can burn off in a day?
    Aug 2013
    Hilton Head, SC
    133
    OK, I've slowly been increasing the "guestimate" on the size of my pool (gallons). Yesterday my FC was 2. based on the pool math calculator, I used 6500g, FC 2, target 5, using 8.25 bleach. Calculator said to add 39oz.
    Now, I am in SC, temps in the upper 80's, very humid. How much FC should burn off in a give 24 hr period. CC is virtually 0.
    thx
    ed
    4k, IG, Gunnite, Jandy Valve, 1HP Haywood, 2" flow, single 2" line for skimming & vacuum, Pentair FNSP 36 DE w/125 GPM Multiport 50 PSI, TF-100 Test Kit, built 1991, Hilton Head, SC
    Butterfly's Avatar
    South Carolina
    10,045
    Re: How much Clorine can burn off in a day?
    Well, lots! What is the CYA level?
    You're done SLAMing when:
    38,521
    With a normal CYA and while maintaining normal FC levels. It is common to have to add 2-4ppm of FC every day.
    Lower CYA and higher FC levels will result in higher losses.
    Aug 2013
    Hilton Head, SC
    133
    CYA is around 40
    Butterfly's Avatar
    South Carolina
    10,045
    Jason gave the best answer to your question.
    With 40 CYA, keep the FC between 3 and 7, and never below 7 3.
    When you dose the pool, aim for 7 FC. Wait 30 minutes and retest to make sure you hit target.
    24 hrs. later, retest and adjust back up to 7.
    Notice your FC is 2 in the first post. That is a no-no and an opportunity for things to start growing.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hello, for the origional topic/question how much chlorine can burn off in a day, this discussion very indepth covers it:
    http://www.troublefreepool.com/threa...ater-Chemistry
    Roughly the half-life (depleted by 1/2) of unprotected chlorine in a pool is approx. 1 hour in full sun.
    Aug 2013
    Hilton Head, SC
    133
    thanks! will target 7. And you meant never below 3, correct?
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Emarshbuck View Post
    Yep, you are correct. I corrected my post, thanks
