Thread: Intex 16x48 up, legs getting close to edge of pavers!
    Jun 2014
    Brentwood, Ca (Nor-Cal)
    206
    Hello all,
    Got my pool up and as it filled a few legs got close to the outside edge of my 12x12x1.75" pavers on the low side. All the legs are straight and not "bowed" atleast and the rope isnt tight on the poles.
    I added a paver to 1 outside one so it doesnt slip off. I thought we had them all centered, I didnt realize they may move that much. I wiggled one and it moved so notdoing that again! I guess it found its "spot".
    Pool is 1" off on the low side which doesnt bug me, pavers close to edge do and one paver under the pool (glad we surrounded with packed sand.
    No kids (yet one on the way!) and mostly for floating/relaxing.
    I dont want to drain right now as I want to test the ground to make sure I get no sinks.
    Can I drain end of Sept/Oct and fix the pavers then re-fill and winterize? Figure thats a good time to do a pump upgrade as well
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2013
    Buffalo, NY
    80
    Re: Intex 16x48 up, legs getting close to edge of pavers!
    Obviously keep an eye on them to see if they continue to move. However, there is no problem with draining to fix at any point in time.
    You could always add a paver now as you have already done. Again, just keep an eye on them. You are within level tolerance so that is something else to monitor closely.
    Jun 2014
    206
    Quote Originally Posted by Synergy2 View Post
    Thank you, maybe I could add a 2-2.5" paver to low side when I pull out the pavers to help leave as well?
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
