Thread: I think I have a leak
    I have an intex pool, so essentially the pool is the liner. I am not sure if I am losing water from a leak or evaporation, but it is dropping fast!
    How much water loss is no longer considered evaporation? I live in Se Texas, and it is in the humid upper 90's here.
    I am not noticing any water around the edges, we have had no rain to speak of, and it is bone dry. Help?
    Hurricane Rita did not kill me, but she killed my pool!
    Intex 36'X18'x52" "elliptical pool"/ Hayward 220 filter/1HP pump 14,364 gal, or so
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: I think I have a leak
    I'd have to say that +/- 1/2" could be considered normal. If you're loosing more than that, I'd start looking for a leak
    Luv& Luk
    -Ted
    Pretty sure I have a leak then, but where would the water go? It isn't coming out under the sides or anything......hmmmm.
    OH well, if it makes it till the end of the summer then I am happy.
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    The water could very well be leaking out the bottom of the pool and being absorbed into the ground beneath it.
    To see if it's just evaporation do the bucket test. Take a bucket, fill it with water and set it near the pool. After a day if the pool water level has dropped more then the bucket level, you have a leak.
    HTH,
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    Mar 2007
    4,160
    You can take a look at the article in Pool School here if you'd like to do a little investigation on the missing water
    Luv& Luk
    -Ted
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    902
    did you check your fittings at the filter and at the side of the pool. My Intex needed to be tightened a couple times a summer because the water would leak out of the return or at the intake valve at the side of the pool. Sometimes it would run down the side of the pool and you would not even notice it for days...Especially if you were not looking for it. Check there
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
