Results 1 to 11 of 11
Thread: Cartridge filter element question
    Jul 2013
    western new york
    62
    I noticed that there are several choices for replacement cartridge filter elements (pleatco, unicell,filber,etc.) Does anyone have any info as to which brand (if any) use the lowest micron rating? Does any manufacturer have anything down around the 5 micron rating?
    15k gal inground Viking fiberglass pool; Hayward Variable 1.5hp pump (Maxflo VS); Hayward swimclear 325 sg ft cartridge filter; Raypak 206A 199k btu nat gas heater; Aquabot Bravo robotic pool cleaner
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Cartridge filter element question
    I have heard of many issues with Pleatco. The fabric is not the same quality as Unicell or Filber. But I don't think any will filter down to 5 micron. Why is that important to you?
    Mark
    Jul 2013
    western new york
    62
    Quote Originally Posted by mas985 View Post
    It's not "important" but given the choice of 15 micron element vs 5 micron I would try the 5 micron. I think it would be nice to achieve filtration levels close to DE without the hassle of DE
    mas985's Avatar
    Pleasanton, CA
    11,742
    It don't think it is possible with a cartridge. Plus the human eye can't see much below 100 microns so I don't see the point.
    Mark
    Jul 2013
    western new york
    62
    For anyone interested, I did find that hayward carries various rated filter elements. https://www.haywardflowcontrol.com/p...14_11503_C.htm
    Thanks echo, that's interesting. I didn't realize that they sold pool cartridges in micron ratings.
    Tom
    In gound vinyl L, ~41,000 gallons, Pentair Clean and Clear Plus 420 cartridge filtter, Pentair 2 speed WhisperFlo pump
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Another option to increasing the filter capability of a cartridge is to add some synthetic DE (cellusose fiber), to a cartridge filter, I've done it in the past and it's worked well. It comes off when you clean/rinse the filter out.
    Jul 2013
    western new york
    62
    Quote Originally Posted by bobodaclown View Post
    Can you elaborate on how this is done? I am interested ... aside from opening day my water has looked great. and I have time to tinker around I would like to try and polish the water further.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Just don't use real DE as that will ruin a cartridge filter.
    Mark
    mas985's Avatar
    Pleasanton, CA
    11,742
    Quote Originally Posted by echo View Post
    Those cartridges are not for standard pool filters so I don't think they would work for a SwimClear. They are for the CFLV filter:
    https://www.haywardflowcontrol.com/c...14_11503_C.htm
    Mark
    Apr 2011
    Murrieta, CA
    2,360
    add cellulose (such as fiber clear) to the skimmer, you don't need to add all that much, maybe enough to raise the PSI 1 on the filter or I think the instructions state add one Fiber Clear cup at a time to the skimmer per the instructions.
