Thread: Field Calibration on Pentair Intellichlor?
    Jul 2009
    Upstate New York
    36
    I recently replaced my ic40. I had field calibrated my old unit before and had heard you wouldn't need to on the newer versions. Of course, I independently verified the salt level as good and the new unit read add salt. I'm trying to field calibrate and its not working. Any advise?
    20,000 gal oval IG, vinyl liner. 1 HP Pentair Superflo pump. Intellichlor ic20 SWCG with easy touch, Sand Dollar SD80 sand filter, Taylor K-2006 test kit.
    Re: Field Calibration on Pentair Intellichlor?
    The older units supported calibration, but the newer units do not.
    With a new SWG cell, the salt test is much more likely to be wrong than the SWG.
    Jul 2009
    Upstate New York
    36
    Are you kidding me? I used the salt strips to verify salt is ~3600 ppm AND my old swg (albeit field calibrated) read good as well. So what now, add salt till new swg is happy?
    Killer95Stang's Avatar
    Sunny SoCal
    591
    I've used the drop test and strips that both put me at about 3600ppm. My intellichlor reads at 3900 to 4050 from day to day. Since both are within range, I just let it be.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Jul 2009
    Upstate New York
    36
    Thats great if youre in range. Im low so swg doesnt turn on
    SkyKid's Avatar
    Apr 2013
    Upstate South Carolina
    137
    I have an Aquapure and it read low salt so I took the easy route and added more salt
    Worked for me and no arguing between what the strip test says and the Aqua pure
    14600gal, In-Ground Fiberglass, Haywood s244t Sand Filter, Jandy Apure35 SWG,
    Haywood 2 speed 1hp pump, Haywood Pool Shark, TF-100 Test Kit http://tftestkits.net/
    Pool School http://www.troublefreepool.com/categ...etting_started
    Never been Pool Stored Thanks to TFP
