Thread: Noisy Pump Replacement
    Jul 2012
    NJ
    21
    Hi - I have a Jacuzzi Magnum Force pump that is about 15 years old. It has gotten much louder this year since opening, and from the research it seems that the bearings are going. I know I can go and try to replace the motor, but I'm nervous about the age and am leaning towards just getting a whole new assembly. The label has worm off, but the original installer suggested it was most likely 1.5HP. The piping is 1.5" from the pump to the filter.
    The installer suggested two: Jandy Flopro 1.5 and also Hayward SuperPump 1.5 . I noticed that the Jandy is a 2" connector, would I still be able to use it?
    Can anyone suggest any other models that I should consider?
    Thanks.
    30k gallon in-ground vinyl, sand filter
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Noisy Pump Replacement
    You can use a 2" connection for 1.5" pipe, you would simply use a reducer. But do you have any high flow rate requirements (e.g. spa jets, waterfalls, etc)?
    If not, I would look at the Hayward MaxFlo XL and the Pentair SuperFlo in a two speed version. You shouldn't need more than 1 HP in either version.
    Mark
    Jul 2012
    NJ
    21
    Ok, that's good to hear, I was hoping that I could just use a reducer. I do not have anything that requires the high flow rate. I'll take a look at your two recommendations. Thanks.
    Jul 2012
    NJ
    21
    Also, i have an Intermatic mechanical timer. Are there any concerns if i put in a 2 speed?
    mas985's Avatar
    Pleasanton, CA
    11,742
    Which one (model) do you have? You can add a two speed timer T106.
    Mark
    Jul 2012
    NJ
    21
    I have a T101R timer.
