Thread: PH Down
    May 2014
    KY
    17
    PH Down
    Hi, I was needing some advice on lowering PH. After 5 partial drains my CYA is finally down to 70, FC 5, TA 110 and PH has been slighty increasing but has leveled off at 8.0. I've never used muratic acid so I'm a little nervous about my vinyl liner. I've seen various you tube video's where some people put in in all one spot and other scatter it around in the deep end. But I'm also curious about the dry acid PH down type and the proper way to put it in. Or do I need even need to be concerned about getting the PH down to 7.8 or so since it has seemed level off and has stayed the same for several days? I would appreciate any advice!!
    18,311 gal. 17 x 32, vinyl, in-ground, 1/2 hp hayward pump
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Re: PH Down
    pH 8.0 is the maximum reported by the test. Your pH may be higher, I strongly suggest you lower it immediately.
    Also, pH tends to go up in a pool, I'd recommend bringing it down to 7.2.
    The recommended way or adding muriatic acid is to pour slowly in front of a return.
    Dry acid is more expensive and adds sulphates, thus it is not generally recommended.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Re: PH Down
    I would worry less with the liquid as there is really no possibility of it sitting on the liner in one place.
    Using liquid is easy, but you do have to be careful of the fumes. I carry the sealed bottle to the deep end of the pool and immerse at least half the bottle before I remove the cap. I then just tilt the bottle and pour some in, recap the bottle and dip it down to rinse off any that may have clung to the bottle. I would suggest kneeling down fully so you are stable before you start.
    You can actually see the cloud of bleach in the water and it mixes/dissipates quickly.
    I don't measure as that is just a way to cause an accident. I add lightly, as I can always add a little more.
    Support the site
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    PH Down
    You do need to get the pH down. Maybe target 7.5.
    The way I add MA is to dip a bucket (around 2 gallon) in the pool, then I pour one or two cups of MA in the bucket. Then I pour the diluted MA from the bucket into the pool in front of a return. If I need more MA, I repeat the process. Then I brush the pool, which stirs up and mixes the water. I have no concerns about my liner.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    Donldson's Avatar
    NW Ohio
    2,917
    Re: PH Down
    I agree, muriatic acid is a much better option. More potent and much less cost.
    If you do use powder either add it slowly in front of a return or broadcast it lightly across the pool while the pump is running.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: PH Down
    When adding any strong acid, even a liquid (Muriatic Acid) pouring slowly over a return you should still lightly brush the area (sides and floor) where you pour to ensure thorough mixing. Until it's mixed, the acid is denser than water and can pool at the bottom.
