Page 1 of 2 12 LastLast
Results 1 to 20 of 35
Thread: Posts not vertical
    Jul 2014
    St. Simons Island, GA
    172
    Posts not vertical
    We just installed an Intex above ground pool, 22' x 52" round. Now that it is full of water, the posts are not straight up and down vertically, but lean in as shown on photograph. We had 3 rambunctious young men playing in the pool and making lots of water movement. I could see the frame moving. Is this dangerous or okay?
    Attachment 31266Attachment 31265
    Home pool: Intex 11,400 gallon AG vinyl pool with sand filter & SWG. Taylor K-2006 test kit - coastal Georgia. I'm also in charge of the Elk's Lodge Pool, which is 55,000 gallons in-ground concrete with sand filter, 2 HP Hayward pump, currently using tri-chlor pucks and cal-hypo system.
    Waldog's Avatar
    May 2014
    Christmas, FL
    189
    Re: Posts not vertical
    I hate to say it... but that does not look good. Especially the one post leaning and pushing against the wood? Yikes!
    Installed May 2014 - 16' x 48" Summer Escapes Pro Series Pool AG Vinyl (6,000 gal) - Intex 2650 Sand Filter - Christmas, FL
    Jun 2013
    Manitoba, Canada
    153
    The rope along the bottom has untied or broken, not good. It is there specifically for that reason you have experienced, to keep the legs from pushing out. The newer models of the pool have that feature, older one do not.
    Going to need to find a way to pull those legs back in, and put the rope back into place. You may have to drain it.
    For an 18' pool, you would need 60' of rope or a strap. One idea you may try is a "ratchet" strap, personally I would get a 2" wide one for the extra strength. Any trailer place, big box hardware store sells them. Menards, Fleet Farm, Home Depot, Loews, or semi trailer parts outlet.
    The longest you can get is only about 30' at best, most are only around 16-20', so you need to get enough to do 60' feet.
    May seem like over kill, but you need to suck those legs back in and hold them in place.
    Jul 2014
    172
    It did not come with a rope, just the white band around the middle that has the little holders in which the legs went. How urgent is it to drain and straighten the legs? Is it dangerous or what?
    Jun 2013
    Manitoba, Canada
    153
    Older models did not have the rope. I would urge you to at least buy a good rope and cinch the bottom of the legs as tight as you can so as to not let them move any more for now, for at least until you can fix them.
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    What does the side opposite this one look like? I'm wondering if your pool is not centered.
    Also, if you try the ratchet trick... don't try to pull the legs back underneath with the ratchet. You could bend them putting that kind of force on them which WOULD lead to catastrophic failure. Just get the ratchets tight enough to keep them in place.
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    He said the pool didn't come with a rope. He's not the first guy I've heard say that about a new Intex. All I can say is that the Intex I had 7 years ago had the rope.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    May 2012
    NW PA, halfway between Pittsburgh and Erie in the PA snowbelt
    159
    My Intex is 3 years old now. Not only do I have the rope on the bottom, but my strap around the middle isn't anything like that. I think my legs are through the strap, not in a sleeve connected to the strap. I could be wrong though.
    I'm in my 3rd summer now. One side, about 3 legs, are splayed out but only slightly. Nothing like those pictures. I leveled everything and if I recall 3 years ago, I had another inch just in that small section to take out yet when we got rain. Then the pool was delivered, the weather cleared, and I forgot about leveling another inch in that section and laid the foam and put my pool up. It hasn't been a problem at all but again, is no where near what those legs you show are.
    My water level is exactly 1 inch different at this section of 3 legs.
    Mike
    22' round Intex UltraFrame pool, Intex 633T 2500gph paper cartridge filter/pump
    with broken Intex SWG, using bleach this year
    TF-100 test kit
    Jul 2014
    172
    MAC.DBLUES: I have not counted the number of legs that are not perpendicular to the ground. Off the top of my head, I'd guess maybe 10% of them, spread pretty evenly around all sides of the pool. When filled, one side was about 2.5 inches higher than the other side, so I simply took a spade and scooped some dirt/sand out from under the legs on the high side, so now it's only 1 inch off level. Making that change did not affect the angle at which any of those legs stood. The ones that are splayed were probably splayed when I started to add water. I just didn't notice them being splayed.
    I don't know physics too well, but on one hand I can see how having legs splayed would be a good thing in that it pushes the circular metal frame inwards. On the other hand, I can see how having vertical legs perpendicular to the ground would provide support to the side of the liner, which seems to be the point of the white band around it.
    I'd hate to think of the damage that 48 tons (11 foot radius squared x 3.14 x 4 foot depth x 7.48 gallons x 8.345 pounds divided by 2000) of rapidly moving water would cause to my house and fence if it were to fail catastrophically.
    I called Intex customer support, but the foreigner I got on the phone spoke English so poorly that she failed to understand what I was describing, no matter how many different ways I described it.
    Jul 2011
    844
    My straps were nothing like his either. Mine legs were placed behind the strap, and not in a sleeve. The sleeve design looks a lot more secure. I would like to know if anyone with the same strap design as the OP has the rope.
    Bestway SWG
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Quote Originally Posted by Vince-1961 View Post
    MAC.DBLUES: When filled, one side was about 2.5 inches higher than the other side, so I simply took a spade and scooped some dirt/sand out from under the legs on the high side, so now it's only 1 inch off level.
    This is your problem. You lowered your legs but didn't lower the bottom of the pool. Because of this, the liner isn't hanging on the frame properly because the frame is closer to the ground than it was designed to be. That is why the sides are bulging out and pushing the legs out. Technically, your pool is still 2.5" out of level, even though the frame is level. The ONLY way you are going to solve your problem is to drain, disassemble, level the ground under the whole pool, reassemble and refill. Intex makes everyone think you can just eyeball level and throw their pools up. But they are careful to say to select a level area (not select the "closest" to level area) in your yard.
    Last edited by jblizzle; 07-02-2014 at 04:43 PM. Reason: Removed response to a deleted post that offered bad advice
    May 2014
    St. Louis, MO
    17
    Quote Originally Posted by GreatCanadian View Post
    Our pool has the sleeve for the legs and a rope at the bottom. The pool was purchased this year, but I think it was actually manufactured last year. The white strap that goes around the pool is situated about a foot higher than the pool in this thread.
    18x52 Intex Ultra Frame
    Intex Sand Filter & Intex SWG
    Pretty sure the 20' Ultra we bought and used for two seasons (last season and the year before) had sleeves like this and no rope. We install on level cement and never had an issue.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Waldog's Avatar
    May 2014
    Christmas, FL
    189
    My Summer Escapes has no rope. Legs go behind the strap that is around the center.
    Jun 2013
    Buffalo, NY
    80
    We bought ours last summer and it has the rope and sleeve.
    Would agree that the center is off though.
    The directions make it sound so easy and setup in an hour!!!....haha. I invested waaaaay more time and money than I would have imagined in setting up my pool correctly. Of which I am obviously glad that I did.
    Intex 16 * 48 Ultra
    2650 Intex Sand Filter
    Hayward Thruwall Skimmer
    Hardplumbed in 2014
    TF100 Test Kit
    Jun 2014
    Northern California
    1
    Just a note that the sleeve the leg goes through was on the outside of the white band as shown in the pics. I spun each one around so the leg would go through the sleeve AND behind the white band. I imagine that has a big effect on the legs pushing out.
    Jun 2014
    Mcgregor Tx
    34
    Our 22' Ultra frame is set up like this with no rope bought this June
    Intex 22'x52" 10.5k round ultra frame agp Intex 16" sand/salt water system pump model#28681eg k2006 taylor test kit
    Jul 2014
    172
    I drained the pool last night. Now I will attempt to "mini-level" the ground by lifting one side at a time. If that doesn't work, then it's complete disassembly and moving it off to the side (major P.I.T.A.). Wife REALLY wants this up and running for July 4. Hmmm.
    Waldog's Avatar
    May 2014
    Christmas, FL
    189
    Tomorrow's the 4th!!! I hope you're up and at it! and by the time stamp on your post it looks like you are!
    Are you guys feeling the effects of now HURRICANE Aurthur?
  20. Back To Top    #20
    Jul 2014
    172
    Quote Originally Posted by Waldog View Post
    No.
    Am refilling now.
    The bottom of the pool is now a bit "lumpy", as all I did was lift up the high side temporarily so I could get under it and shovel sand/dirt out. Also dug out room for some pavers on the low side and put them under the legs. I get the nagging suspicion all I've done is make it worse, but we'll see how the water settles in.
