Results 1 to 10 of 10
Thread: Connect SunQuest Solar Pool Heater to Intex 1.5" hose?
    Jun 2014
    Toronto, ON, Canada
    98
    Hi all,
    I was wondering what was the easiest way to connect a sunquest solar pool heater to an Intex 1.5"? I have a 12'x30" metal frame with 2800 gph sand filter. Now I want to attach the solar heater but I'm not sure how. I've read a lot of posts but my head is spinning.
    Please help!
    Thanks.
    Re: Connect SunQuest Solar Pool Heater to Intex 1.5" hose?
    The easiest way is probably to get a set of Intex hose to PVC adapters, glue the PVC side of the adapter to the connectors on the panels and then connect your hoses to the other side.
    Jun 2013
    Manitoba, Canada
    153
    See my photos of the one I did, I think its exactly what your looking for, or close to it. I bought all the parts at HD.
    http://www.troublefreepool.com/threa...nough-to-enjoy
    Jun 2014
    Toronto, ON, Canada
    98
    Thanks. I don't have the panels yet. Once I get them it might make more sense.
    12' Intex Metal Frame Pool, 1500 gallons, Intex 2800gph Sand filter/pump, AquaPro PRO1100 HP, K-2006 Test Kit
    Jun 2014
    Toronto, ON, Canada
    98
    Looks like all I need are these adapters. Fits directly into the panels and now I can use the intex hoses.
    Jun 2013
    Manitoba, Canada
    153
    Perfect
    Jun 2014
    Toronto, ON, Canada
    98
    When connecting the hoses to the headers is it okay to connect both hoses on the same side of the panel? I am connecting two panels side by side but want the two hoses connecting to top and bottom headers both on the left side since this is the side against the pool.
    Jun 2014
    Toronto, ON, Canada
    98
    Got my panels hooked up today. The only problem is I can't get the end caps to stop leaking. Any advice or tricks on connecting them without leaking?
    Jun 2014
    Toronto, ON, Canada
    98
    Well google is your friend. Did 8 rounds of teflon, hand tightened, then quarter turn with wrench. No more leaks!
    Jun 2014
    Toronto, ON, Canada
    98
    Water reached 91 today! Panels work great!
