Results 1 to 8 of 8
Thread: Water results
    Jun 2014
    Shepherdsville Ky
    16
    Water results
    I just had my pool installed on Friday filled it and added salt. Used liquid chlorine until I was able to turn on the swg. Tested the water and here are the results
    Fc 1
    Cc 0
    Ta 80
    Ph 7.2
    Cya 55 this was as of yesterday it should still be rising
    My question is how do I get the ph to rise with out effecting ta we have been in there for the last three days and I have been splashing like crazy along with my 4 year old and the ph is not really changing. I know that the ph needs to be between 7.5 and 7.8 for swg and the ta between 60 and 80 and according to pool math if I raise my ph .3 it is going to raise my ta 11 which would put me in the 90's. So my question is how do I do this?
    17,500 gallon 27' ag. Ecco 19" sand filter 1-1/2 hp pump 45gpm. Zodiac aquapure ei swg.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Re: Water results
    The SWG will take care of raising pH. Don't worry about it.
    You need to turn the percentage up or get some more bleach in there.
    Jun 2014
    Shepherdsville Ky
    16
    Re: Water results
    I have it running at 40% from 9:30 am to 8:30pm so should I try 60% for the same time or let it run longer and what does my free chlorine need to be at? Also what are the best salinity test strips the ones from walmart are garbage or I am not good enough to use them I added 560 lbs of salt and they say my salinity is 800 lol.
    Richard320's Avatar
    Jan 2010
    19,000
    Re: Water results
    Quote Originally Posted by Black Z View Post
    http://www.troublefreepool.com/conte...art-slam-shock tells you what to target. Or poolmath. How to set that up with recommended levels and all is here.
    Don't know about salt strips. I just pour bleach out of a jug.
    Jun 2014
    Shepherdsville Ky
    16
    Re: Water results
    Why would I add bleach? Shouldn't I be able to do this with my chlorine generator?
    Richard320's Avatar
    Jan 2010
    19,000
    Re: Water results
    Either or. But the SWG could take hours to build FC up, whereas a jug adds it all in a matter of seconds.
    Just fiddle with pump run times and SWG percentages. You'll find the winning combination in a week or two.
    Jun 2014
    Shepherdsville Ky
    16
    Re: Water results
    Thank you so much I went out and retested not in the sun and I am at 3ppm on chlorine. Which according to this is http://www.troublefreepool.com/conte...rine-generator is the low side but should be ok?
    Re: Water results
    With a SWG, as long as CYA is 70 or lower and FC never goes below 3, then you are alright. It is nice to have a little more margin in case something goes wrong, though not essential.
    Your PH will go up on it's own, without raising TA, due to the aeration from the SWG. It will probably take a little while, but it will go up.
