Thread: newly filled pool and green water!!
    kimbow64's Avatar
    Jun 2013
    Lafayette, Indiana
    6
    Last night filled new above ground pool. Clear water. Today, tested water, plugged and chugged numbers in pool school calculator. Added bleach, borax, and CYA. Then about hour later the pool water turned green. Is this from the metals in the water? I joined Pool School last season with a different pool and followed the "seasonal pool set-up" using the shock method. I saw the set up used is a different this year but I followed it to the letter. Do I just need to purchase something that removes the metals from the water or did I screw something up? Thanks.
    3,800 gallons, AG, Seasonal pool,. HTH 6-way test kit
    Mar 2014
    Las Vegas
    288
    Re: newly filled pool and green water!!
    Sure sounds like metals to me. Wait for one of the experts to chime in on how to deal with it. Its above my paygrade.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    That's very common the first time bleach hits the iron. If it doesn't just fade away in a day or two, then you'll need to buy a metal sequestrant.
    http://www.troublefreepool.com/conte...d-metal-stains
    kimbow64's Avatar
    Jun 2013
    Lafayette, Indiana
    6
    Thank you!!!!
