Thread: CC is it 0.5 or 1?
    gatorbrit's Avatar
    Aug 2013
    Raleigh,NC
    95
    CC is it 0.5 or 1?
    I did my chlorine test using the powder and I show 0.5 CC. But after a couple of minutes the test solution is pink again - so I add another drop of R-0003 reagent to get to clear. Total drops is now 2 = 1 CC. Does this additional drop "count" towards to the total? I am guessing yes, because the solution should stay clear and perhaps I am not mixing enough.
    Either way, I am SLAMing tonight.
    18k vinyl IGP, Sand Filter, EasyTouch Control Sys, Pentair Intelliflo, Intellichlor IC 40 SWG, Rheem Heat Pump.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: CC is it 0.5 or 1?
    No. It will always go pink again if you wait long enough.
    Donldson's Avatar
    NW Ohio
    2,898
    No, the solution naturally turns pink again if left alone for a few minutes. Once you turn it clear the test is over.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    gatorbrit's Avatar
    Aug 2013
    Raleigh,NC
    95
    Thanks everybody - that helps a lot.
    Still, I think I will SLAM just to get rid of the 0.5 which hasn't gone away in a week. I think something is eating my chlorine.
