Results 1 to 7 of 7
Thread: PLease help with clogged skimmer line.
    Jun 2014
    Central Florida
    36
    I am fairly new to pool maintenance. I was paying someone to it but he is currently unavailable. I thought it would be a good time to learn myself. Anyway, I purchased 2 1lb bags of shock to treat my pool. The bag said either to spread it around the pool or that it can be poured into the skimmer with the pump running. I removed the basket and poured in the shock. The skimmer line is now clogged and I can detect no suction coming from it. I assume I added the powder in too fast and it blocked the line. I tried using a garden hose and putting it down the hole. That did not work. I dried using a drain bladder to force the clog out. That didn't work either. Any advice would be appreciated. Thank You.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,031
    Re: PLease help with clogged skimmer line.
    Go the other direction. Shut the pump off, open the strainer and remove the basket, and stick the drain bladder in the pump inlet and see it blasting the other way helps.
    Jun 2014
    Central Florida
    36
    I'll try that. The drain bladder I used through the skimmer burst open almost right away.
    Thanks
    22,000 gallon in ground, gunite, Hayward pump 1.5 hp and 36sq DE filter. Pool installation date unknown, at least 10 years. Screened enclosure.
    Jun 2014
    Central Florida
    36
    When I used a drain bladder through the skimmer, the bladder popped. I tried going through the pump end like you suggested but the suction port for the vaccum and the skimmer are connected. The bladder didn't pop but all the water is going through the hose suction port. I tried closing the cover and holding it in with my hands, but water is still forcing its way out the sides and nothing is coming through the skimmer line.
    Richard320's Avatar
    Jan 2010
    19,031
    Sounds like it's time for a plumber.
    Jul 2011
    phoenix
    133
    Dumb question but did you make sure your diverted valve (if you have on) was set to skimmer all the way? Reason I ask is a co worker had the same problem, called a plumber and he opened the skimmer side fully and the used a drain king (same thing he had tried but with skimmer part way closed) and worked
    13k IG pebble pool w/waterfall, 1hp whisperflow pump, pentair ccp320 cartridge filter
    Circupool SI45+ swg
    TF100 +speed stir Taylor 1766 salt test
    Jun 2014
    Central Florida
    36
    Quote Originally Posted by Iciee View Post
    I figured that out. I feel pretty silly now. Since I have never really taken care of my pool myself, I wasn't sure how all the valves worked. I assumed the skimmer and vacuum where connected. Fortunately,
    I noticed the problem before I made a service call.
